Roto-Fab
Old 08-18-2012, 11:28 PM   #1
jasycz28
J.Sick
jasycz28's Avatar
Drives: 2010 Camaro SS
Those with Chillers what are your IAT's?
Just wondering what your guys IAT's are? (NOT THE TEMP OF HEAT WATER.)
What is your ambient temp?
What are your IAT's at idle with the chiller on?
What are your IAT's on the highway with the chiller on?
I am trying to see if my kit is working correctly. Again I don't care about the temp of the water, I am only concerned with your IAT information.
Thanks
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline   Reply With Quote
Old 08-19-2012, 08:45 PM   #2
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
Here's my IATs with a super muggy 83F ambient temp.
bumblebeecamaro is offline   Reply With Quote
Old 08-19-2012, 08:52 PM   #3
audiomikej
audiomikej's Avatar
Drives: the wife crazy talking Camaros
What is this display? I want that!
audiomikej is offline   Reply With Quote
Old 08-19-2012, 08:57 PM   #4
jasycz28
J.Sick
jasycz28's Avatar
Is this driving or at idle? Either way my temps only go about 20 degrees less than ambient. When driving. They stay right around ambient or about 10 degrees higher at idle. Anybody else have info?
Thanks bumblebeecamaro.
"J.Sick"
2010 Camaro 2SS
Old 08-19-2012, 09:09 PM   #5
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
Thanks
I normally see 92-97 ambient, Idle chiller on IAT 70 and highway IAT 60-65 in normal mode and in comp mode about 5*-10* less. Peak IAT on a 1/4 mile run at the end IAT 115-120* , and if chiller is off IAT is at *150.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 08-19-2012, 10:27 PM   #6
jasycz28
J.Sick
jasycz28's Avatar
I can't get anywhere close to those IAT's. My high side and low side AC pressures are in the correct range. I am going to datalog some more over the next few days just to make sure.
"J.Sick"
2010 Camaro 2SS
Old 08-20-2012, 09:23 AM   #7
Turbo99
Turbo99's Avatar
Does your cabin air feel good inside? It should feel cold as stock if not your freon level is in correct. I had this issue with mine as I was the first 5th Gen. to get one and it took us about 3 tries to get the freon level correct, sometimes it would cool the chiller good but not the cabin and then it would do the opposite, third time we got it right just adding alittle at a time until it did the job all around.
Old 08-20-2012, 09:41 AM   #8
jasycz28
J.Sick
jasycz28's Avatar
AC in the car is really cold. I am going to check my pressures again tomorrow. I was told (RX) that the AC pressures will let you know if you need to add or take freon out.
"J.Sick"
2010 Camaro 2SS
Old 08-20-2012, 06:29 PM   #9
B.Buster
B.Buster's Avatar
Drives: 2010 AquaBlue 2SS/RS
Which SC do you have? Some have more efficent ICs that lower IATs more
B.Buster is offline   Reply With Quote
Old 08-20-2012, 06:38 PM   #10
Turbo99
Turbo99's Avatar
he has a chiller, it bypasses the chiller when the A/C is engaged. Has nothing to do with the I/C. But yes a better I/C will help IAT but not in his case.
Old 08-20-2012, 07:46 PM   #11
SC2150
Drives: 2012 Camaro RS, RX supercharged
turbo99 is running 30* below ambient on the highway, your at 20* below so not far from him. Still may need some freon tweaks but make sure the HE bypass is totally bypassing the HE or your fighting the ambient air temp trying to chill the outside air.
SC2150 is offline   Reply With Quote
Old 08-20-2012, 08:15 PM   #12
Turbo99
Turbo99's Avatar
Mine also fluxuates going down the road, so 30 below ambient is on the better end and on the lower end I will see 20 below. I started see higher temps and about a month later my A/C clutch was gone, so I just got a new clutch and I will see if that keeps mine more steady like it was when I first put the chiller on.I think I have an issue with my clutch re-engaging during WOT, we saw it on the dyno graph but I need to put a camera on it when on the dyno and see, my car has 13K miles and the A/C clutch looks like it had 100K on it. As I said we saw a blip in the dyno with the a/c on where the clutch went off and then a dip at 5500rpm where it looks like it came back on.
Old 08-21-2012, 12:04 AM   #13
jasycz28
J.Sick
jasycz28's Avatar
I know for sure the HE is bypassed because it's not hooked up right now.
"J.Sick"
2010 Camaro 2SS
Old 08-21-2012, 03:34 PM   #14
B.Buster
B.Buster's Avatar
I also have a chiller. I was talking about the IC in the SC , not the FMIC. I should have been more clear.
