11-19-2010, 05:15 PM | #1 |
Drives: 2010 AquaBlue 2SS/RS Join Date: Sep 2009
Clutch freeplay 1" then goes away (searched)
As stated, when I use the clutch (after sitting a while) I have 1" freeplay where there is no resistance. The car shifts nomal but the grab is lower. It feels like air in the system. After driving about 50 shifts, the peddle comes back to normal where there is resistance from the top. I don't believe this is the clutch TSB. Any thoughts? I will try bleeding the clutch this weekend but the fact that it fixes itself seems not to be the prob. Thought I read somewhere that these are self bleeding. Car has 4K miles. Thanks
11-20-2010, 06:13 PM | #2 |
I guess I'm the only one with this prob
11-21-2010, 03:46 PM | #3 |
Drives: 2SS LS3 Join Date: May 2010
no you're not. Just had it happen to me today for first time (7000mi). There is less resistance in the top 2" of play, then went away after a while.
2010 CGM 2SS LS3, born: 4/10 |
11-21-2010, 05:00 PM | #4 |
Not just any car!
Drives: Orange Krate DOB - 11/22/2010 Join Date: Oct 2009
Air vs. cylinder leakdown? Hmmm.
11-21-2010, 05:54 PM | #5 |
SSLarry, mine started by surprise one day. Thing is I park it and it's OK then the next morning it has freeplay on the first press. I will try bleeding tomorrow if possible.
11-21-2010, 07:59 PM | #6 |
Drives: 2015 ZL1/2016 Malibu LTD LTZ Join Date: Jan 2010
have u checked the oem specs on how much free play the maro is supposed to have?
11-21-2010, 08:46 PM | #7 |
When working properly "Zero" freeplay
11-23-2010, 08:17 PM | #8 |
In all cars there needs to b a lil free play not a lot but u should have sum
11-23-2010, 08:47 PM | #9 |
Emerald Coast Camaros
Drives: 2010 2SS 6m Join Date: Mar 2010
Location: Fort Walton Beach...surrounded by da** pickup trucks I can't see around!
Bleed it, but it will be difficult without a remote bleeder installed.
Procharged F1A-94 on a 416 LSA block, Callies/Manley/Scat/Melling/Cloyes/ARP/Ferrea/Landspeed/Hi-Ram/FIC/Tick/Alky/ Strange/QA1/DSS/BMR/RPS/Tilton/GZM/Fore/AEM/ATi/JGS etc., built/tuned by me and Innovative Street Technologies
'Mo's Seemingly Endless Build Thread |
11-25-2010, 10:11 AM | #10 | |
Drives: 2010 IBM 1SS (Former) Join Date: Feb 2009
11-25-2010, 04:21 PM | #11 |
My prob went away as fast as it arrived. Been working fine for a couple days now. The only thing I did was open reseviour. Maybe the cap is not vented that well . If prob comes back I will bleed.
11-25-2010, 08:36 PM | #12 |
Drives: 2011 2SS/RS SIM L-99 Join Date: Jun 2010
Same reason I got an auto...just couldn't get mine fixed. Good luck man, try a clutch reservoir and better fluid n replace it often.
3rd Time is the charm
2012 2SS/RS VR 6M. Borla S type, Volant CAI. |
12-01-2010, 09:46 PM | #13 |
Found the quick fix.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
I want a new clutch, you too????? Sign here | tjbusa | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 370 | 08-10-2013 03:27 AM |
Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
Clutch being replaced | MillerTime | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 29 | 10-25-2010 04:37 PM |
Clutch Problem | phenixdragon | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 20 | 08-22-2010 10:51 AM |
Oil Change Ramp | mjlash22 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 01-21-2010 10:40 PM |
