07-20-2020, 05:35 PM | #15 |
Drives: 2018 Camaro SS HW Edition, 2020 LT1 Join Date: Jan 2017
Still not wanting to ship?
1987 Camaro IROC-Z 6.0 LS 4L80
1988 Camaro IROC-Z TPI 5-Speed 1992 Camaro B4C 5.7 TPI 2018 Camaro SS Hot Wheels Edition #838 |
07-20-2020, 09:35 PM | #16 |
07-30-2020, 07:25 PM | #17 |
Still available
08-05-2020, 03:24 PM | #18 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Pm
Hey! If they are still available I’m interested. Do they come with TPMS Sensors?
08-05-2020, 06:14 PM | #19 |
Hi, no sensors, sorry. I'm only selling tires here and TPMS sensors are typically bundled with wheels. The pics in the OP might be misleading you, I'll shoot new ones of just the tires as soon as I find some time.
08-30-2020, 04:52 PM | #20 |
Quick question if I may ask... Did running oversize tires by the 10mm for 255 front and 285 rear create any issues with handling,braking, cause any speedo error or rubbing of the tires inside the wheel wells or body etc ? Did these fit well on the stock SS rims ?
Thanks in advance |
08-30-2020, 07:42 PM | #21 | |
The speedo readout will be a little bit off, see picture below, however, the change is actually in the "right direction"—that is, the speedo reads higher from the factory for safety (just like all other cars), and this change pushes it closer to the actual speed.
08-31-2020, 07:01 AM | #22 | |
Hot Camaro
I'm asking because I have found the speedo to be off by a fairly consistent 1MPH using GPS speed calculating from Waze and other apps in the car. This is on tires with 2k on them, so the delta will drift slightly more as the tires wear and the diameter / circumference decrease (and revolutions per mile increases). |
08-31-2020, 01:19 PM | #23 | |
08-31-2020, 01:23 PM | #24 | |
Hot Camaro
I can't validate anything against those "neighborhood" things as there is always too much traffic and they seem to be set on non-level ground (so you can't set your cruise control or similar and drive by to see what it might show). |
09-04-2020, 04:20 PM | #25 |
Bump—rainy season approaching, pick up these top notch tires and forget traction and stability problems in the wet (with almost no tire noise).
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 09-05-2020 at 01:08 PM. |
09-21-2020, 09:31 PM | #26 |
Bump—someone pick up these beauties that will stick to the road with authority, dry or wet.
10-08-2020, 08:53 AM | #27 |
Drives: 17 2SS 6sp Join Date: Jun 2020
Just pmed you. I'll take em!
10-09-2020, 06:36 PM | #28 |
Drives: 19 Chevrolet Camaro/ 15 GMC Sierra Join Date: Aug 2019
If that deal falls I’m interested.
