12-05-2017, 08:02 PM | #1 |
Drives: 2018 Camaro 2SS, Garnet Red Join Date: Jan 2014
Vmax ported throttle body throwing codes and loss of power
Received my Vmax ported throttle body in the mail today. Installed it as per instructions, by video. Everything was connected. I started the vehicle and immediately started getting throttle body error codes and reduced power. Engine was chugging and probably running lean. The car died before I was able to shut it off. I reinstalled by stock throttle body and the car started as normal, with the check engine light still on. I've currently disconnected the battery and will see if the car is going to reset the code. Did I get a bad throttle body from Vmax? What could cause this?
12-05-2017, 08:21 PM | #2 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
yes, bad tb from vmax. get it exchanged.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
12-05-2017, 08:22 PM | #3 |
Send it back and get one from Pray Performance.
2016 NFG 1SS A8
12-05-2017, 08:38 PM | #4 |
Cars running fine with stock, no CEL. It was definitely the throttle body. I might have to look into Pray. We'll see if JDP makes this right.
12-05-2017, 09:16 PM | #5 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I dont care what anyone says, if you are changing the TB out then unplug the negative on the battery first before you start the swap.
Then once you are done go thru the idle relearn process. |
12-05-2017, 11:30 PM | #6 |
12-06-2017, 01:20 AM | #7 |
Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
I'm sure it's a defective one...Hope they make it right for you.
I just installed the PRAY one and it's great. Gonna install the Rotofab tomorrow!
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
12-06-2017, 11:54 AM | #8 |
Drives: 2017 Camaro SS 1LE Join Date: Nov 2015
From what I've seen it is not uncommon for the throttle body motors to be bad on some of the brand new ones sent out by GM. Mine had a bad motor in it and it was a brand new throttle body that PRAY purchased as an OEM GM part. Just get it returned and replaced
Show: C7 Carbon ZL1 Front Splitter/C7 Carbon ZL1 Side Skirts/Diode Dynamics LED Sidemarkers/Tinted Headlights, Fog Lights, and Rear Reflectors/20" Forgestar F14's in Bronze Burst
Go: 17" Forgestar F14s in Bronze Burst with Hoosier Drag Radials/Rotofab Intake w/ Dry Filter/EFI Flex Fuel Kit/Kooks 2" Longtubes with Offroad Connections/PRAY Performance Ported Intake Manifold/PRAY Performance Ported Throttle Body/PRAY Performance Ported Heads/PRAY Performance Tune Suspension: Phastek Lowering Springs/BMR Toe Rods/BMR Control Arms/BMR Trailing Arms/BMR Strut Tower Brace |
12-06-2017, 01:16 PM | #9 |
Drives: 2016 2SS Join Date: Jul 2016
Did your headers finally show up? LOL.
12-06-2017, 01:23 PM | #10 |
The motors in these TB's are HOT GARBAGE. They are weak and are sync'd to the cover. This is the most garbage TB I have ever seen from GM. I have been porting them since 04'. It makes it very difficult for porters to get every throttle body perfect for every car. I have gone through three revisions to eliminate issues. Issues are random as crap as well. You can do 100 TB's that work awesome and then there is the one car that no matter what you do won't work on that particular car. PITA.
12-06-2017, 01:44 PM | #11 |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
