08-25-2017, 11:18 AM | #1 |
Drives: 2017 Hyper Blue SS Join Date: Jul 2017
Dreaded lifter knock? Or paranoia?
Hey everyone! I'm 23, and recently bought myself a 2017 1ss with the A8 and NPP, I've worked my balls off for this car so every little thing worries me, the other day I was Reading this thread
http://www.camaro6.com/forums/showthread.php?t=505440 Now this morning I thought I heard the same knocking sounds but not as loud, only when cold but it went away after my 45 min drive to work. Now I know this is useless without video so I'll post one tonight, but do you guys think I'm being paranoid or is this a serious concern? Only have 4200km on the car. Thanks!! |
08-25-2017, 06:35 PM | #2 |
The Black Emerald
Drives: '17 ZL1, '08 Trailblazer, '11 1LTRS Join Date: Sep 2011
Any kind of knocking sound and I'd turn the car off and call roadside assistance. My Camshaft split and caused a rocker to collapse under normal driving
08-25-2017, 06:44 PM | #3 | |
Did you end up getting a new engine? If so, How's the new one? |
08-25-2017, 06:54 PM | #4 |
Thank you Al Oppenheiser!
Shady, check your oil.
08-25-2017, 09:36 PM | #5 |
08-25-2017, 10:27 PM | #6 |
Yes. Because dealers.
08-26-2017, 08:50 AM | #7 | ||
Drives: 2011 Camaro SS Join Date: Apr 2013
Lifter tick is a very light sound in tight rhythm with the firing of the engine cylinders and goes away if you rev the engine from a cold start or drive it for a little while. It's very normal on most cars. Almost all 5th gens had this. Mine has it, and I've ignored it for years now -- hasn't gotten any worse or better but is generally more noticeable in winter.
Based on the video in the first page of the thread you cited, whatever that other guy was hearing was not your average "lifter tick." That is engine knocking + what sounds like random debris clanking around inside the engine with abnormal timing: https://youtu.be/0xcwPPBzpn8 To be clear that has nothing to do with lifters, at least directly. In the OP's case, his engine sounded like metal was clanking around because... there was metal clanking around. His camshaft disintegrated from impact with the lifters. Aside from that coincidental fact, it wasn't your average lifter noise by any means. It was the metal shards. I'd hope most people would pull over immediately if their engine sounded that bad, as its in a class of its own pretty much. What normal lifter tick sounds like What abnormal lifter tick (technically "lifter knock") sounds like (begins at about 5 seconds in.)
Disclaimer: Unless specific sources are cited, all of the above is my subjective opinion. No warranties, expressed or implied, are granted. This is a car forum, after all.
08-26-2017, 09:05 AM | #8 | |||
But it's not rythmic like the first one either I don't think. Can I post a video without using YouTube on here? |
08-26-2017, 09:22 AM | #9 | |
Near the attachments area when you create a new post on this site, it states: "Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd txt zip" So you could technically put the video file in a .zip but it'd be easier to just host it elsewhere.
08-26-2017, 01:57 PM | #10 |
Having trouble hearing that knocking, turned on the car this morning after being off all night, listened closely and didn't hear it, I only heard it that one day, and it was a colder day.
08-26-2017, 02:20 PM | #11 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
Mine has a rhythmic tick when cold as well. I've heard a lt1 corvette start up the other day, and I identified the same sound. Rhythmic ticking that goes with the rpm is fairly common, and I don't think it should alarm you. If the tick gets louder, and begins to knock, record a video for proof, shut the car down, and have it towed to the dealership. Keep that warranty intact guys haha!
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
08-28-2017, 10:23 AM | #12 |
Finally heard the sound this morning, recorded it, will upload video here later, it is rythmic, and off camera I gave it a little gas and the speed went up/down with rpms
08-28-2017, 10:34 AM | #13 | |
SoCal HT5! SD
http://www.camaro6.com/forums/showthread.php?t=506235 Engine sound database in the issues sub forum.
08-28-2017, 10:35 AM | #14 |
________/\_
DI injectors can also make a ticking sound.
