07-05-2017, 12:45 PM | #15 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
the problem has been discussed before but not as a result of idling a long time with the AC on........check out this thread...it might help.
07-05-2017, 01:52 PM | #16 |
Drives: 2016 1 SS Hyper Blue Metallic Join Date: Feb 2017
07-05-2017, 03:11 PM | #17 |
376 cubic inches of fun
No way should the car be overheating, even idling at 95 deg. If this was a stressing condition, then people could never be in a traffic jam in Texas.
I hope the OP follows up and tells us what was found. |
07-05-2017, 04:37 PM | #18 |
Drives: 2017 50th Anniversary Join Date: Dec 2015
The car needs to go to the dealer to be inspected. Sounds almost like the fans didn't come on or the coolant level is low causing the issue.
Idling for extended periods of time does not hurt anything and certainly should not cause over heating of a properly functioning new car. Back in the 90's my uncle was involved in hot weather testing for GM. While I can't say that GM still does this today. One of the hot weather testing practices was to drive the prototypes aggressively on desert roads in southern CA then immediately park the car nose first in a metal shed in the blazing sun with the air running and let it idle for hours in 100+F heat. If the car overheated then it was back to the drawing board. Long story short..... Something caused the car to over heat and it wasn't letting it idle with the air running. |
07-05-2017, 08:53 PM | #19 |
Thank you Al Oppenheiser!
Come to FL and try convincing people of that.
07-05-2017, 10:00 PM | #20 | |
________/\_
Mostly true but with prolonged idling on a regular basis, I would be concerned about intake valve carbon fouling in a DI engine. |
07-06-2017, 05:32 PM | #21 | |
@maplefed
Drives: 16' MBM 2SS, Join Date: Sep 2016
I'm sitting in my car idling in 95 degree ambient with a blower and an air to air ntercooler with my A/C on, in my black car. As I do regularly for 30minutes plus at a time.. The way my car is driven I'm not sure carbon stands a chance lol.. Dealer will make it right OP!
@maplefed
07-06-2017, 06:14 PM | #22 | |
Drives: MB 1SS Join Date: May 2017
BTW if you put coolant in your oil it will help with overheating. |
07-06-2017, 06:21 PM | #23 | |
Drives: 2017 2SS, M6, HBM Join Date: May 2017
Single mom Dad who had someone else service absolutely everything Interweb expert ....?? All kinds of barriers to knowledge but no barriers to belief. |
07-06-2017, 06:26 PM | #24 |
Drives: 2018 HBM SS 1LE Join Date: Jun 2017
07-06-2017, 07:41 PM | #25 |
I think this guy nailed it. Before you even go to the dealer pop the hood with the A/C on and see if the fans are running. The A/C won't even work if the fans aren't running when the car is standing still. The A/C compressor will short cycle on the high pressure cutoff. You can usually hear this happening. This sounds like your problem. Since you have no A/C and engine overheat at idle, there is a shared component that failed-- the fans.
07-07-2017, 03:22 AM | #26 |
Drives: 2017 ZL1 and 2018 SS 1LE Join Date: Oct 2015
Happened to my 16, the cooling fan stopped working
07-07-2017, 08:09 AM | #27 |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
Issues are separate. 1) sounds like a problem that needs to be fixed. 2) it's not generally good to idle the engine for long periods of time, regardless of the temp
07-07-2017, 08:39 AM | #28 |
I appreciate all of the responses. looks like we're taking it to the dealer next Thursday.
