11-19-2018, 03:11 PM | #15 |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
I didn't see any switches on them, the Helix has this option from what I have seen.
11-19-2018, 03:47 PM | #16 |
Drives: 2016 Bright Yellow Camaro vert Join Date: Jul 2015
Good luck with the fix. I have a base 1lt convertible never could get the ones from China with the yellow turn lights to work. Brakes and 4 way flashers fine. Including extra flash when brakes actuated. But the turn signals would flash 3 times then go in to the Hyper flash. You may have better luck with the SS/RS... Worked with company first they said I had car issues voltage too low what have you, Then they sent a second light harness, It worked no better. So I returned them this afternoon. I'm pretty sure the Helix are different. Close up shots look like you can 'almost' see reflectors on the Helix and Helix has a switch for fixed or sequential turn signals. Unfortunately they are about $100 more plus an adapter for the LT Camaros I believe...
11-20-2018, 06:24 AM | #17 | |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2018
Material possessions are junk in terms of eternity |
11-20-2018, 02:02 PM | #18 |
I tell you what, Next Gen Speed sure does give you the run around when it comes to a refund, they claim that these lights are what they showed on their web site which is false because they never showed anything other than the turn signals and hazards, nothing about how the brake lights go out when you apply brakes and use the turn signals and the when the turns come on when you apply the brakes, so yeah this should be on vendor to avoid. I will give it another shot and see what happens next.
11-21-2018, 03:46 AM | #19 | |
Drives: Too many to list Join Date: Dec 2011
Same ones. Yes, hyperflashing was fixed. Blinking hazards has emerged. Sent from my iPhone using Tapatalk Pro |
11-21-2018, 03:49 AM | #20 | |
They’re dangerous. The lights may confuse someone who is distracted and driving too closely due to the flashing hazards when applying the brake. I don’t know what you’re talking about in terms of reflection or in terms of blurriness. Not to mention I don’t stand behind my car at distance to notice any of these things. I have GM dark tails, I’ve always had them so I’m switching back to them. Sent from my iPhone using Tapatalk Pro |
11-21-2018, 03:50 AM | #21 | |
There’s a circuit board with diaper switches inside the housing. If you unscrew the cap, you can pull out the circuit board with the switches. Sent from my iPhone using Tapatalk Pro |
11-21-2018, 04:50 AM | #22 |
11-21-2018, 10:05 PM | #23 |
You can so whatever you’d like. I don’t mess with them. I’m just telling you they’re there. I’m taking mine off.
11-22-2018, 12:15 AM | #24 |
Drives: 2013 Camaro 1SS & 2015 Camaro SS Join Date: Oct 2013
We were part of the design process for the Helix ones, so I can assure you they do not have hyperflash, they don't turn on when brakes are pressed and don't have reverse camera issues.This is one reason for the price difference amongst them. We recently released our version of the more affordable ones (just now posted under sponsor classifieds) and may have placed built in provisions to address the known issues. It varies by years and vehicles, due to BCM interpretation and other factors, but we have a harnesses etc that fixes all problems if need be. As of now we are at a 92% success rate. Meaning majority of the of the cars will work with them out of the box. For the other 8% that don't, we have a solution and will work with our customers to take care of them. A member here has been testing our versions for about 6 months now with 0 issues. I hope this sheds light on your concerns. IF not feel free to DM us to discuss in further details.
11-22-2018, 08:31 AM | #25 | |
Drives: Camaro Join Date: May 2018
The only thing that surprised me was that the demos I saw had yellow turn signals and my set has red ones. |
11-22-2018, 10:53 AM | #26 |
[URL="https://youtu.be/iW7O9Xtnzr4"/URL]
I changed out the VLAND tails for these and I like them better, the turn signals are pretty bright at night. |
11-22-2018, 10:54 AM | #27 |
11-22-2018, 02:28 PM | #28 |
I returned my Vland lights and have the Helix lights on order. That 15% off from Ebay yesteray made the cost at least close. Vland did try with a second harness and refunded the purchase price right a way when returned. Should have the Helix by Friday the 30th...
Tags |
next-gen, next-gen speed, sequential, smoke, tail lights |
Thread Tools | |
