07-25-2023, 12:08 PM | #1 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Oil Pressure Consensus after supercharging your car
I asked a couple people here about their thoughts on the oil pressure they are running after changing to forged internals and supercharging their car.
My question or instance... my oil pressure (from the dumb gauge) usually read about 30-40 PSI in stock form and didn't vary much after warm up. After installing forged internals and the Whipple, I noticed my oil pressure at 60-70 PSI (cold at start up) and 50-60 PSI after warm up. I am currently running 0-40 Mobil oil after doing the oil change from the break in oil. I asked my tuner as I was concerned, and he stated that it was normal as I had new bearing and pistons with tighter tolerances, and it will come down some in time, but the oil pressure is good. So... am I concerned for nothing? the car has less than 2000 miles on it, so I assume the oil sender is fine, and it seems to read correctly. Any thoughts here?
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
07-25-2023, 12:26 PM | #2 |
35 on startup, 62 just after the gear shift at peak rpm
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 07-30-2023 at 05:42 PM. |
07-25-2023, 02:29 PM | #3 | |
Drives: Chevy Camaro Join Date: Sep 2022
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels 1.45 4.01 6.07@120.74 9.28@153.43 '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild Last edited by jlaudio11; 07-25-2023 at 02:48 PM. |
07-26-2023, 06:03 AM | #4 | |
07-26-2023, 06:22 AM | #5 |
Also on forged internals for ~8000 miles, oil pressure on mine is around 40 psi on cold starts, goes down to 32-33 once warmed up and cruising, mid-40s under intermediate load and maybe 65-70 at WOT (I don't stare at the gauge cluster at WOT, so it's approximate). I don't see how your much higher oil pressures would be desirable.
07-26-2023, 07:40 AM | #6 | |
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels 1.45 4.01 6.07@120.74 9.28@153.43 '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild |
07-26-2023, 09:53 AM | #7 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
Sure you didn't get an upgraded oil pump when you forged the internals?
07-26-2023, 10:02 AM | #8 |
Nope... stock oil pump (but a upgrade may be in my future if this one fails)
07-26-2023, 10:07 AM | #9 |
Drives: 2016 Camaro SS Join Date: Oct 2021
Mine with forged internal is about the same as everyone's. mid 40s normal driving and jumps to 60 or so at WOT.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
