Vararam
Old 01-30-2011, 08:00 PM   #15
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Do you feel that the scoop's build and the way it's mounted can long term handle the weight of the tank, pump, and 2 quarts of fluid? I don't have a scoop yet so just curious.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 01-30-2011, 08:06 PM   #16
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
I had not considered that. I do not believe it will be a problem. It is made from aluminum sheet. The vertical wall is only about 4 inches tall and the depth is about the same.
13 ZL1 is offline   Reply With Quote
Old 01-30-2011, 08:38 PM   #17
IndeedSS1
IndeedSS1's Avatar
Pop riveted, heliarced, nothing, or something else?
Old 01-30-2011, 09:21 PM   #18
13 ZL1
13 ZL1's Avatar
Is there a question here?
Old 01-30-2011, 09:31 PM   #19
Should be solid enough to hold the washer fluid tank...
Old 01-30-2011, 09:58 PM   #20
Fraxum
Fraxum's Avatar
Really creative. Looks good. I just stuck a cheap WWF tank where the old airbox post is next to the CAI box.
But if I had to do it over I would get the new Roto-Fab tank. Check it out.
Old 01-30-2011, 10:08 PM   #21
AC
***GO HOGS GO***
AC's Avatar
Drives: 68/327 & 10 2SS SIM w/ CGM Stripes
awesome, good work.
ProCharger F1A, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension, CCW 10"/11.5", DBA Rotors, 3.91's, 560/570 hp/tq
ProCharger F1A, VMax TB, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension & 4 Point Strut Tower Brace, 3.91 Gears, DBA Rotors
Heritage Grille, CCW SP16a Wheels 10"/11.5" Nitto 275/40 315/35, Painted Calipers, Blackout: Bowtie, Rear Panel, Markers & Side Vents,
SS Fender Badges, 6.2L Cowl Lettering, Pistol Grip Shifter, RPI SS Door Kick Plates, Billet Cup Holder, Fesler Shift Boot, Lloyd Floor Mats..(1/4: 12.917 @ 109.63)
AC is offline   Reply With Quote
Old 01-30-2011, 10:19 PM   #22
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
looking good
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 01-31-2011, 01:36 AM   #23
IndeedSS1
IndeedSS1's Avatar
Sorry, I figured it was assumed from the earlier question.
mlee - thanks looks like a total of two pop rivets and the method of mounting more than enough to support the side loaded weight.
Going to check on ordering later this morning.
Old 01-31-2011, 09:48 PM   #24
13 ZL1
13 ZL1's Avatar
One of the vendors here on the forum has agreed to carry this washer assembly. It will take a few weeks to get parts from the manufacturer. All of the details are being worked out and will be posted as soon as possible.
Old 02-01-2011, 06:31 AM   #25
IndeedSS1
IndeedSS1's Avatar
I'm in. Now is one of those times where I wished I had patience.
Old 02-10-2011, 01:50 PM   #26
CRUSHER2SS
CRUSHER2SS's Avatar
Drives: 2010 Camaro 2SS/RS
Any updates on this yet?
"We don't stop playing because we grow old; we grow old because we stop playing"
2010 2SS/RS L99-Black-658RWHP 582Tq - Magnuson TVS 2300 SC -w/OD COG
LS3 Conversion - GT9 CAM - Ported Heads
ADM-Race CAI - GM ZL1 Heater Hose Kit- KB BAP
Kooks-1 7/8 LT Headers, Corsa-Cat-back
Tune ECM & TCM - VMAX Ported TB - Posi Mod -
Pfadt - Drag Coilovers, Motor mnts, Trailing Arms, Camber Plate, Control Arm Stiffeners, F&R Bushing, Pfadt ZL1 Balance/Sway bars, Sub frame, Diff bushing
Nitto-NT05R DRs 315/35R20
ZL1 Prototype Wheels (10's Ft & 11s Rear) - RB Front Rotors
MPD1 Spoiler
CRUSHER2SS is offline   Reply With Quote
Old 02-10-2011, 02:18 PM   #27
13 ZL1
13 ZL1's Avatar
The last I heard was on Monday, the vendor was getting ready to place an order with the manufacturer.
Old 02-15-2011, 09:03 PM   #28
13 ZL1
13 ZL1's Avatar
Install Update
With the setup as previously described, if I overfilled the tank, the excess would leak out through the vented lower cap. I switched the caps back the way I had it originally with the unvented cap on the tank. I then put a section of 1/4in tubing inside of the original tubing all the way down to the fitting on the tank. I expect this to act as a vent to eliminate the pressure build up that previously prevented the tank from filling. Unfortunately, I did not have the lower cap tight enough when I filled it. I had water leak past the cap threads. Therefore, I am not yet certain that this fixes the problem but I expect it will. Here are some pics of the final install of the remote fill.
My Baby is home! 2SS/RS Black w/IOM Michael_Js Member Car Journals 144 08-13-2011 04:41 PM
ADM RACE SCOOP INSTALL PICS ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 11-08-2010 09:11 AM
Washer fluid bag for ADM race scoop?? Robbie1227 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 10-11-2010 05:25 PM
ADM Race Intake Scoop install help plz! azvren Camaro DIY & HOW-TO instructions & discussions 1 03-03-2010 05:48 AM
ADM Performance CAI??? Kodiak Ak Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 11-07-2009 05:24 AM
