Old 06-12-2014, 09:16 PM   #1
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Another intake manifold option I stumbled across...
While doing some research for a future experiment, I stumbled across this:
It's a crossover style setup, similar to... The one you're all waiting for... IMO, this company has done the hardest part for you, the rest is left up to your imagination and the limitation of your skills (or wallet to pay for someone elses skills)... I guess these are built for an ITB setup, but if you wanted to build a plenum for each side and run dual TB's it would be possible, or even dual plenums into one TB...
If I still have a v8 car, I would have a set of these on the way to me right now...
http://www.jenvey.co.uk/home/manifol...s3-sfd52-mct03
They've also got them available for LS 1/2/6 and 7
Old 06-12-2014, 09:30 PM   #2
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Great find. Not a bad deal at $700 bucks.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 06-12-2014, 09:53 PM   #3
Jason@JacFab
That's what I was thinking. And the rest of the work required is pretty easy stuff.
Old 06-12-2014, 11:11 PM   #4
1989GTA
Drives: 1989 GTA Trans Am
I have built intake manifolds in the past and the runners are the tricky part of it. The plenum is the easier part in comparison. However IMHO the Vararam product looks pretty good.
1989GTA is offline   Reply With Quote
Old 06-12-2014, 11:46 PM   #5
Jason@JacFab
It does look good... But when will it come out? Hence why I posted this, it seems like a great basis for a lot of builds and it's available now.
Old 06-13-2014, 12:57 AM   #6
chevybowtie
Drives: 2010 Camaro
In that case why not just modify a Holley ram phenomenon. A lot less complicated then even this option.
chevybowtie is offline   Reply With Quote
Old 06-13-2014, 02:56 AM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Runners are too short on the holley. They kill low end tq.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 06-13-2014, 11:48 AM   #8
Jason@JacFab
I've got one of those foam LS1 mock up blocks... Wonder if it would bolt on? Hmmmmm....
Old 06-17-2014, 08:21 AM   #9
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
Check out how their velocity stacks seem to have the same bolt pattern as the throttle body base. To be able to tuck those in a plenum would probably aid airflow with the port transition from round to rectangular.
Seems like a viper style dual plenum could be fabricated to keep the height low and leave the injectors and rails where they're at.
Irnwkrkev is offline   Reply With Quote
Old 06-17-2014, 11:04 AM   #10
DesertCamaro
DesertCamaro's Avatar
Drives: Fast
That would look so sick peeking under a hood with a see-through insert
2014 SS
DesertCamaro is offline   Reply With Quote
Old 06-17-2014, 12:44 PM   #11
That_Guy
That_Guy's Avatar
Drives: n/a
I'd like to have it with the itb's... if only it wasn't $4k.... Still a better option than the unicorn-ram at this point.
That_Guy is offline   Reply With Quote
