Old 09-26-2019, 10:44 PM   #1
Bassment
Drives: 2016 Red Hot 2SS M6
Help! Can't get the recommended trans or diff fluid in Canada
I have a 2016 2SS and need to do the 72,000 km maintenance. I am planning on using https://www.amazon.ca/Royal-Purple-R.../dp/B001DKTG0G for the transmission fluid and https://www.amazon.ca/Mobil-104361-7...ve&sr=1-1&th=1 for the rear axle fluid
Is that ok? Is it only 1 quart for the transmission fluid? I saw a video where the guy used almost 2 quarts.
I can not get the ACDelco GM recommendation in Canada for some reason
Bassment is offline   Reply With Quote
Old 09-26-2019, 10:50 PM   #2
Bassment
Looks like it's 4 quarts for transmission and 1.2 quarts for diff?
Old 09-26-2019, 10:55 PM   #3
Bassment
Or I will use this for diff https://www.amazon.ca/Line-57904-75W.../dp/B000CPCBF0
Old 09-27-2019, 12:03 PM   #4
Daily1LE
Daily1LE's Avatar
Drives: 2018 Camaro 1SS 1LE
I just did this on my 18 Camaro 1LE. I went with Redline D4 ATF for the trans
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The gallon bottle should be enough as you should be adding just about 3 3/4 quarts or so. I think you fill until you're like 1/8 inch below the fill hole. But I just filled until it overflowed then removed about 8 ounces.
As for the diff, I used the AcDelco stuff.
From the research I did, it seems this is what most use, so I can't comment what might be good besides that. I put in about 1.6 quarts in my car. Hopefully others can recommend if you can use the Redline stuff. If the Trans stuff is good I would think the rear diff is too?
Daily1LE is offline   Reply With Quote
Old 09-27-2019, 12:48 PM   #5
mikem2104
mikem2104's Avatar
Drives: 18 2SS 1LE, 20 Canyon Denali
you've got double posts going on ... in your other post i mentioned that you 100% can get the OEM fluids as well as aftermarket of your choosing.
Redline, Royal Purple or OEM is all available through Amazon.ca, Canada Tire or local Chevy dealer.
Good luck
Mike
Current Garage:
18' 2SS 1LE, Hyper Blue
23' GMC Canyon Denali
Previously:
20' GMC Canyon Denali
16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss)
14' Ford Edge Sport
06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada
mikem2104 is offline   Reply With Quote
