05-30-2022, 03:46 PM | #1 |
Drives: 2012 ZL1 #1329 M6 Join Date: Jun 2009
LSX 454
I got a new in the crate finished LSX 454 block along with everything needed to finish it. PM me if interested.
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports 784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128 Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms http://www.camaro5.com/forums/showthread.php?t=395950 Rapid Motorsports 396ci Build https://www.camaro5.com/forums/showt...1#post10321301 10.832 @ 130.99 |
05-31-2022, 10:16 AM | #2 |
Drives: 2010 2SS/RS LS3 Join Date: Apr 2011
Can you post some pictures? Price?
06-01-2022, 01:34 PM | #3 |
PM Sent
06-02-2022, 04:21 AM | #4 |
Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
send me info also please
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146 |
06-02-2022, 05:24 AM | #5 |
GMPP LSX Front Cover 12633906 -$115.96
GMPP LSX Rear Cover 19369274 -$364.22 GMPP Valley Cover Plate 12599296 -$133.99 GMPP Head Bolt Kit 19257453 -$121.83 GMPP Head Gaskets 19170419 - $196.24 GMPP LSX-LS7 CNC Ported Heads 19419197 -$2,364.18 x2 GMPP LSX 454 Block 19417353 - $3,922.00 GMPP LSX Controller for Manual Trans - $1,500.00 GMPP Front Completion Kit 19299099 - $298.91 GM Cam Bolts 11588723 -$67.92 GM Intake Gaskets 89060413 -$62.96 GMPP Rear Cover Cable Gasket 19166181 -$3.51 GMPP Rear Cover O Ring 19166180 -$3.55 GM Crank Shaft Oil Seal 89060436 - $21.71 GM Intake Rocker Arms 12579615 -$122.08 GM Exhaust Rocker Arms 12579617 -$134.16 GM Cam Bolt 11588723 -$33.96 Callies Dragonslayer Crank 4.125 - $1,605.00 Lunati X Beam Rods- $1,272.00 Mahle 4.185 12.1 Piston Kit - $848.00 Mast Oil Paint Assembly -$564.65 ARP Main Stud Kit 234-5608 -$243.79 LSA/LS9 Valve Covers with Coils/Fill Neck - $560.36 Tony Mamo Cam with Valve Springs and retainers - $600.00 Total- $17,525.16 Everything is new in the packages. I just want to break even on the deal.
06-07-2022, 10:53 AM | #6 |
Drives: 1LE 2ss Join Date: Dec 2017
Would you sell just the short block?
2015 2SS/RS 1LE
AGP TT, COMP AC 62’s, BTR Cam, Pump/Meth, Fore Innovations LC2/FC3, ID1300’s, Bo White TB, Corsa, McLeod RXT, GFB G-Force II, Tuned at CSP SBE 819/755 |
07-05-2022, 01:51 PM | #7 |
Bump.
11-09-2022, 05:40 AM | #8 |
BUMP.
02-17-2023, 03:59 AM | #9 |
Drives: Zl1 Join Date: Sep 2018
Pics of valve covers
05-30-2023, 05:43 PM | #10 |
Engine is in the process of being built. Still for sale.
Thread Tools | |
