08-31-2023, 10:00 AM | #1 |
BBL-BEE
Drives: Bright Yellow SS 1LE Join Date: Mar 2023
Is this normal oil pressure for these rpms
My engine is the 3.6l LFX v6. Is this normal oil pressure for these rpms? I have been burning some oil and put almost a quart in about 2200 miles into the oil change. What can I do to fix it if isn't. Should I sell it? Please help.
08-31-2023, 10:58 AM | #2 |
Drives: 15SS Camaro Join Date: Dec 2020
normal
08-31-2023, 12:09 PM | #3 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
Totally normal as Paul stated. One (1) bar is equal to 14.5038 PSI, you good.
08-31-2023, 05:44 PM | #4 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
While the pressures appear acceptable, that 232 degree oil temp seems a bit high. Not critical but hotter than normal. I drive my V6 in 120 degree weather and my oil temp has never been above 212 even after an 80 mph freeway commute to work. Were you running it hard prior to that pic? What was the ambient temp?
08-31-2023, 08:18 PM | #5 |
Drives: 2011 Camaro rs Join Date: Jun 2023
I'd change that thermostat to a 180 degree one, keep running that with 232 degree's your head gasket is gonna go bye bye.
Sidenote: as for oil, i had that happen once in my Rs original engine, i ran Rislone engine treatment in it, it stopped the issue. |
08-31-2023, 08:30 PM | #6 |
Drives: ABM #93 Join Date: Oct 2018
I don’t see where he ever hit 232 on coolant temp…. Hot oil isn’t going to kill a head gasket it’ll kill other things but the head gaskets aren’t likely.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
09-02-2023, 11:14 AM | #7 |
Oil temps are fine
09-10-2023, 11:35 PM | #8 | |
BBL-BEE
