TireRack
Old 04-18-2023, 05:03 PM   #1
JGaschTT
Drives: TT 2010 SS Camaro,Stock 2010 Camaro
AGP Twin Turbo HP numbers.
I have been trying to finish my car for about a year trying to turn it into a drag and drive car. I am hoping for 1000 whp and wondering if anyone has similar set ups and what hp your pushing. I have a 416ci stroker kit, AGP Twin 6865s 1.06a/r, Jakes Stage 4 4L80e ,IDX1350s and all accompanying mods. I am leaning towards running VP MS109 race fuel does anyone have any experience with running MS109 with a setup similar to mine?
2010 2SS-Texas Speed 416ci Stroker Kit, Jakes Stage 4 4L80e with D3 Transbrake, AGP TT 6865 BB, BTR Stage 3 TT Cam, AGP Triple Walhbro 450s, AFR 260cc Heads, ID1300x Injectors, BMR Racing Suspension, BMR 15 Inch Conversion. Hoping for 1000+ and running 8.50 in the 1/4mile.
JGaschTT is offline   Reply With Quote
Old 04-18-2023, 05:56 PM   #2
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
Attached is my dyno. 6565 agp twins. LSX427. 4L80 Trans. Fuel is E85 usually at 77%
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 04-18-2023, 06:33 PM   #3
JGaschTT
What do you run in the quarter mile?
Old 04-18-2023, 06:48 PM   #4
Scuzz
Scuzz's Avatar
She is of the roll racing breed. no 1/4 time.
Old 04-19-2023, 01:55 AM   #5
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
Have you ever “Miled” her?
Sounds like a beast…
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 05-09-2023, 11:18 AM   #6
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
I'm curious how you gained over 1000rwhp/100rwtq at the same boost level? Nitrous or was the tune conservative then more aggressive?
2010 Camaro SS M6 - 416ci TT 989rwhp/1031rwtq @ 20psi
2014 ZL1 A6 Vert - Headers and CAI
RealQuick is offline   Reply With Quote
Old 05-09-2023, 03:37 PM   #7
blake-b
blake-b's Avatar
Drives: 2009 ZR1
LSX427 AGP6565s. TR6060 through Gforce 9". We couldn't get it to hold more than 21lbs which turned out to be a controller setting. After that was later figured out, it was never dynoed again. Picture is cutoff but the smoothing is on 5.
It made just over 1kwhp on 13lbs or so. After the new owner put it on a dyno, he said it made 1189whp on low boost (mid teens if I recall).
Scuzz and I had very similar setups. The major differences being him having a 4L80 and mine a manual. I also had a Holley Hi Ram with LSx LS7 Frankenstein heads and I believe he had a stock intake manifold and different heads than I.
Old 05-09-2023, 07:58 PM   #8
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Frankenstein m311s? What headers are you running? Planning on installing AGPs kit soon. Stock motor, FED M311 heads, cam, 6262s on 10psi is the plan.
CamaroDreams76 is offline   Reply With Quote
Old 05-11-2023, 08:04 AM   #9
jeff657756
Drives: 2014 SS 1LE
You will have to run the huron manifolds or something like an ARH shorty header or get the stock manifolds clearanced. Huron said they are about 6 weeks out on their manifolds.
jeff657756 is offline   Reply With Quote
Old 05-12-2023, 02:48 PM   #10
CamaroDreams76
Thanks, I was wondering how long the Huron Speed headers would take to make.
Old 05-12-2023, 04:14 PM   #11
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
If gonna run the Huron headers, only way I could keep my plug wires from melting was to run ceramic caps. I tried those insulated socks and aluminized sleeves (and both at one time) but always melted the caps. Since ceramics - been hunky-dory.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 05-12-2023, 08:58 PM   #12
CamaroDreams76
What about the 45 degree plug wires like the hooker blackheart headers? Do you think they'd be sufficient? I had to run those with that header because they'd literally melt right through the sock and wire.
Old 05-12-2023, 10:12 PM   #13
dreksnot
dreksnot's Avatar
I didn't have any luck with 45* or straight plug caps with the Huron headers. Always fry city on a few of the cylinders regardless. Ceramics were the only fix for me.
Old 05-13-2023, 03:14 PM   #14
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Just curious, what do you need to clearance on the stock manifolds? Thanks.
HOJO is offline   Reply With Quote
