06-29-2021, 09:49 PM | #1 |
Drives: Chevy Camaro 2015 2SS RS Join Date: Feb 2020
Experiences with GPI SS1 Blower Cam?
Hi, just like the title said, I would like to get some feedback on the GPI SS1 Blower Cam. I know most people are doing the SS3 Blower Cam, but since my car is still my DD I prefer to idle more like stock (gf doesnt like it too choppy and rough idle)...
I am unable to find any vids with the SS1 blower cam, so anybody with experience please share. I will be doing l99 to ls3 conversion with this cam, the same time I install the Magnuson heartbeat. Car has kooks Long tube with cats and also a borla atak catback... hopefully it wont be much louder than it already is lmao. thanks |
06-30-2021, 07:19 AM | #2 |
shoot an email to Ben@Gwayneyperformance.com and we can talk over exactly what you are looking for and what you can expect out of the parts you choose.
Ben |
07-01-2021, 12:40 PM | #3 | |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
07-01-2021, 12:48 PM | #4 | |
I think the blower cams are slightly different than the NA cam and that normally from what I see, the NA cams are generally louder with more lope? correct me if im wrong. Thanks |
07-01-2021, 08:08 PM | #5 |
Might try calling or emailing Ben from above and see if they can do a custom camshaft that has a smooth idle and the power your looking for.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
07-02-2021, 04:17 AM | #6 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I would agree. Because I have the SS1 cam not the blower though so I don't know what the difference in specs are but I would say it you don't like a nice chop and a bit of bucking in gear I would give them a call and see what their options are. Some say a torque converter will help with the cam but I'm not sure.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
07-03-2021, 08:21 AM | #7 |
If I'm not mistaking, the lope and idle quality is all determined by the LSA (lobe separation angle) of the cam. Also yes the cam will make your sound a lot louder with the higher lifts in the exhaust events of the cam, mine got about twice as loud as before the cam. If you are concerned about the bucking and idle driving characteristics of the cam, a converter setup right will eliminate all that. I am running a TSP stage 3 cam and a big intake manifold and a 4200-4500 stall and all is fine. Good luck and have fun. I would do as stated above if you are going with the GPI cam, call Ben and chat about what it is you are looking for and want to do with your build. Lots of guys on here are running GPI and they offer god knowledge and info on the VVT cams.
07-03-2021, 03:18 PM | #8 |
Thanks for all the replies! I was hoping if someone could share direct experience with the blower ss1 cam but this is good too
08-08-2023, 10:27 AM | #9 | |
Drives: 2014 Camaro 1SS (A6 Ashen Gray) Join Date: Sep 2019
Hey, I've been considering the exact same cam+supercharger combination. If you did it since then, how do you like it? Did you get a certain torque converter as well?
Mod list: GPI SS3 camshaft (VVT delete), ZL1 Fuel Pump, FIC 60 lb injectors, Tru-Cool 40k tranny cooler, Circle D 3600 triple disc (billet flexplate), GPI Rod Mod, Bo White ported TB, Variant Helium wheels, Continental ECS 02 tires, CAI cold air intake, Kooks 1 7/8" LTH w/ high flow cats, Ridetech HQ coilovers, BMR sway bars, BMR delrin subframe bushings, Hendrix offset poly diff bushings, Borla S-Type axle-back exhaust, Holley EFI Fuel Rails, Elite Engineering E2 catch can, Umbra LED Taillights, Kenwood DMX9707S head unit, some minor interior/exterior appearance mods.
09-06-2023, 06:10 PM | #10 |
Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
Late to this thread but I have seen a ss1 blower in a cts v. It has some lope, more than my custom spec cam from gpi. I have a custom grind from gpi 216 228 118 and it has a baby cam idle. Not really a lope but anyone who has been around 5th gens will be able to tell it's cammed.
If you don't want any lope you are going to need a cam with overlap similar to mine. Basically -12 overlap or more. |
09-09-2023, 08:36 AM | #11 |
Here is my $.02....
First off, decide if 'GF' is a permanent modification Secondly, choose your car modifications based on what YOU want....unless this is the only car AND your gf drives it, too. If that's the case, reference the first step again. Lastly, if a factory smooth idle and drivability is your goal, the LS9 camshaft is a great economical cam upgrade that will give a factory smooth idle, great driving manners, and allow for a nice power bump as well. The LS9 camshaft doesn't require aftermarket valve springs, hardened pushrods, etc. -Scott |
09-11-2023, 11:06 AM | #12 | |
We have made over 800 RWHP with this cam so it is not limited by any means. Our Rough Idle blower cam has extremely good Driver manners as well but we do recommend a converter with this one. Ted.
www.jannettyracing.com
Tags |
blower cam, cam, gpi, heartbeat, supercharger |
