TireRack
Old 10-26-2012, 04:49 PM   #1
GMParts
GMParts's Avatar
Drives: 2011 1SS/RS CGM
DELETE
mods please delete
GMParts is offline   Reply With Quote
Old 10-26-2012, 04:54 PM   #2
Camper
Drives: 10' 2SS LS3 M6
the better question is why would you install ported heads with no cam install?
they will yield you very very minimal results on a stocker cam
Camper is offline   Reply With Quote
Old 10-26-2012, 09:50 PM   #3
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
LS3 conversion, the lifters in the L99 are only good for one thing, unique paper weights.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 10-26-2012, 09:56 PM   #4
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
They will work just fine.
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 10-27-2012, 12:23 AM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If you won a set of nice ported heads, why not just wait till you have the $$ to do it right. That means put the good hardware and a good cam in it. No since in wasting $$ taking everything apart for just a set of ported heads with stock hardware and cam.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 10-27-2012, 02:06 AM   #6
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
I agree about the lifters although they have nothing to do with whether you can use a VVT cam or not.
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
kaler is offline   Reply With Quote
Old 10-27-2012, 08:54 AM   #7
2SS45th
2SS45th's Avatar
Unless you're using boost, then you don't want VVT, too much hassle.
Old 10-27-2012, 10:40 AM   #8
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Wrong.
Cam only, 11.3 with vvt.
Rhino79 is offline   Reply With Quote
Old 10-27-2012, 10:39 PM   #9
axis
Search Ninja
axis's Avatar
Originally Posted by GMParts View Post
This I what I am doing,, just trying to get an idea of what all I need!!
Shouldn't be too hard to find that out. Look at the vendors heads and see what hardware they're using. Then start researching prices. You can also search this section to see what others are using. Since you're not in a hurry, keep an eye out in the forsale sections to see if you can grab some parts at a discounted price.
Halltech CF 102 fed
Old 10-27-2012, 11:58 PM   #10
kaler
kaler's Avatar
Sorry a boosted application would benefit in the same way a N/A application does.When you use a cam like the VVT-3 you have to do a AFM delete. Think of it as a "LS3 conversion" with VVT. The only difference between my set up and a "LS3 Conversion" is the cam phaser that gives you the ability to adjust the cam timing on the fly no hassle there just win in my opinion.
Old 10-28-2012, 12:06 AM   #11
kaler
kaler's Avatar
Once you decide on a cam lots of people on here can point you in the right direction or talk to one of the vendors on here. Are the heads assembled or bare? If assembled find out what springs they installed.
Old 10-28-2012, 12:32 AM   #12
2SS45th
2SS45th's Avatar
In import, where VVT has been around much longer, high boost applications almost always delete VVT. The main reason? You can run much more aggressive cam profiles without it, which will make more power and work better with boost. And generally high hp means high boost, therefore VVT and boost are not the preferred setup. There isn't a single VVT car on the fast list, facts talk.
Old 10-28-2012, 03:26 AM   #13
kaler
kaler's Avatar
Next time someone post something like: Sorry a boosted application would benefit in the same way a N/A application does.
Instead of this:Unless you're using boost, then you don't want VVT, too much hassle.
Maybe some thing like this would be more appropriate: If you are building a max effort,high boost,huge cam,stroker engine a VVT cam may not be your best choice.
Then I would have responded with some thing like: Listen to 2SS45th he knows what he is talking about get the hell away from that VVT cam.
