04-29-2021, 07:14 AM | #1 |
Drives: 2020 Camaro 2SS Convertible Join Date: Sep 2018
OEM Vs Aftermarket rims
I'm gonna pull the trigger on a set of rims 1LE or ZL1 (20x10 and 20x11) style.
im just trying to decide wither to pay the extra an go with the GM ones or go with a aftermarket and save some money. what do you guys think? should i pay the extra? are the GM ones built better? TIA |
04-29-2021, 07:47 AM | #2 |
Drives: 2019 Camaro 1SS Join Date: Apr 2019
I'm sure the OEM ones are better quality but I am running MRR wheels and am pretty happy with them. One track day with no issues. If I decide to change them out in the future I will probably look for a gently used set of 1LE OEM wheels.
04-29-2021, 08:29 AM | #3 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Depends on what you plan on doing with them. The GM ones are forged while most aftermarket in the money-saving price range are flow formed, meaning the GM ones will stand up to abuse better. That doesn't mean that the aftermarket wheels aren't OK for most situations though. If you're doing lots of hard track driving and bouncing off curbs or hitting other rough spots consistently you'll be more prone to bend most aftermarket wheels, but if you're not constantly going 10/10ths and slamming curbs on the track and running through potholes aftermarket should be just fine.
2017 SS 1LE.
04-29-2021, 10:45 AM | #4 |
oem or bust
05-11-2021, 10:10 AM | #5 |
Drives: 2017 Chevrolet Camaro 1LT Coupe Join Date: Jul 2020
I love aftermarket rims. Just bought a new set from 4wheelonline, an American Racing Wheels.
05-14-2021, 10:59 PM | #6 |
Forged wheels are always better, OEM or aftermarket. I have MRR 1LE replicas, they are fairly good and hold their ground, but there is a reason the OEM SS 1LE wheels cost twice as much.
06-18-2021, 01:16 PM | #7 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
06-19-2021, 02:44 PM | #8 | |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
That being said, My aftermarket forged wheels shave more than 30lbs from the factory wheels while matching the factory specs.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
06-19-2021, 07:26 PM | #9 | |
06-20-2021, 08:40 PM | #10 |
Tampa Bay Camaros
Drives: 2017 Krypton Green 2SS Join Date: Jul 2011
I went with 5th gen ZL1 factory reproductions. Love them.
Sent from my Note 20 Ultra 5G using Tapatalk
Me and wife, in order
2011 2SS SGM 2013 2SS Hot wheels vert 2016 C7 DSOM 2012 2SS yellow vert 2017 2LT Krypton Green 2018 2LT Hot wheels crush 2020 2SS Shock vert. 2017 2SS Krypton Green coupe |
06-29-2021, 08:44 AM | #11 | |
Yep, some GM wheels shown there (Corvette and Camaro). With the weight of them, cast+flow-formed ("flow-forged") made a lot of sense, but I guess GM just put an extra layer of safety factor in there. |
07-04-2021, 10:33 AM | #12 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Like others said, if you track, oem or aftermarket forged. Autocross cast or flow formed fine. Street only same. All up to what you want safety wise. Cast are cheapest. I have a old set of cast xxr wheels I use for autocross from my old fifth gen and are fine after six years and 100 track days. Flow formed are good for most uses and run around $2200. Then there are
Forge lines and those and oem are tops for hard track use, but cost $6000 |
07-04-2021, 07:20 PM | #13 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Like everyone says. It depends on your risk tolerance and wallet.
I ran 6 cheap wheels as a track set for several years on my 5th Gen. 2 cracked and 2 bent. I went with OEM wheels for the 6th Gen.
07-05-2021, 10:26 PM | #14 | |
