View Poll Results: Who has experienced an oil pump failure? | |||
2016 or earlier | 20 | 13.79% | |
2017 | 53 | 36.55% | |
2018 | 67 | 46.21% | |
2019 | 2 | 1.38% | |
2020 | 2 | 1.38% | |
2021 | 1 | 0.69% | |
Voters: 145. You may not vote on this poll |
Thread Tools |
07-17-2021, 03:49 PM | #799 | |
Drives: 2019 ZL1 Join Date: Mar 2019
As long as its the proper filter, no.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
07-18-2021, 06:02 PM | #800 |
Drives: 1985 Z28 Join Date: Aug 2020
I meant using a Mobil 1 oil filter with incorrect PSI bypass valve.
07-18-2021, 06:51 PM | #801 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
So much for "stay away from 2017's" LOL
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
07-19-2021, 01:15 AM | #802 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Just to open this up a little bit. Can the oil pressure sensor be the culpit, at least in some of the reported failures?
https://www.camaro6.com/forums/showthread.php?t=594185
Mosaic black 2018 Camaro 2SS A8 (sold) |
08-07-2021, 12:22 AM | #803 |
Drives: Zl1 2019 Join Date: Aug 2021
Justo Bought My Zl1 win only 4000 miles, its a 2019 ,someone knows if i have the updated oil pump?how can i know it? thanks!
08-07-2021, 03:34 AM | #804 |
Drives: '17 ZL1 M6 Join Date: Apr 2021
Adding a Katech oil pump with the cam job as a precaution. Back order was nasty and I was lucky to make the recent batch
Anyone here running one?
'17 ZL1 M6
8xxwhp Magnuson 2650 |
08-07-2021, 05:34 AM | #805 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Running great so far.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
08-07-2021, 06:21 AM | #806 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
First step in the TSB is to use the GM filter & correct oil. If the issue persists then further diagnostics is required. There are different types of failures as well. The variable actuator failure, I think, was either a fault in engineering/ production or incorrect materials, think the valve spring failure scenario. |
08-07-2021, 07:31 AM | #807 |
Drives: 2019 ZL-1 Join Date: Feb 2009
2019's seem to be fine compared to 17-18.
2012 Yukon XL Denali w/ 6.2 AWD |
08-31-2021, 09:54 AM | #808 |
Drives: 2018 ZLE Join Date: Apr 2018
Welp, add me to the list.
Build: 07/17 MY: 2018 Mileage: 4,XXX Reduced engine power CEL after a spirited drive, a few more miles of normal driving then zero oil pressure. Towed home. Going to the dealer hopefully this week.
2018 ZL1 1LE (CARBON/PDR/NAV)
08-31-2021, 10:15 AM | #809 |
Petro-sexual
That sucks... Sorry for your troubles.
08-31-2021, 10:43 AM | #810 | |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
I'm patiently waiting... MY 2018 with build date of 11/17, 7400 miles so far.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
08-31-2021, 02:52 PM | #811 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
CEL/low oil pressure you should get the car towed immediately, I wouldn't drive it another yard
09-01-2021, 05:01 PM | #812 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Doubt it. My pump failed at 16k miles and I always used the AC Delco PF64 filter from the dealer and Mobil 1 oil...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
Thread Tools | |
