06-12-2019, 09:18 PM | #15 | |
Soon to be Millionaire
Drives: Blue 2016 Camaro Join Date: May 2016
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look |
06-17-2019, 05:13 PM | #16 |
Drives: 2010 Camaro Join Date: Nov 2009
We can refer you to a FL Facility that has replacement billet units made that corrects this and greatly improves acceleration, but that's about it.
Looks like limited success from GM and this is a very widespread issue across many platforms. Email direct: Tech@EliteEngineeringUSA.com for more info. Thanks! |
06-19-2019, 04:22 PM | #17 | |
That being said, if I have an ASE certified mechanic saying a part needs to be replaced and he does the diagnosis and work, my extended warranty company said they'd cover it in full.
06-19-2019, 08:37 PM | #18 | |
To create an aluminum casting, one must first create a mold of the part that is to be created. The mold is formed when the pattern is pushed into chemically binded sand leaving the impression of the part to be casted. Once the mold is complete the molten aluminum is poured into the mold and allowed to cool and harden. Once the molten aluminum solidifies, the mold is pulled apart and out comes the desired part. On the other hand, billet aluminum is formed in a completely different manner. To understand completely how a billet aluminum part is made, it is necessary to understand what a billet is. A billet is a solid block of aluminum (or any material) with the size depending on the size of your desired part. The larger the desired part, the larger the billet. Contrary to casting, billet parts are created by removing excess material from the billet, essentially the part is carved out of solid block. |
06-24-2019, 09:28 AM | #19 |
Drives: 2016 2SS Camaro Join Date: Mar 2018
I never bothered with the dealer after getting a run-around on the issue and they couldn't find any information on the TSB.
I changed to Amsoil fluid and the problem is solved. Hasn't returned. I listed in detail the events to this (somewhere on this forum)... the best I can recall without looking into the details is 12,000 miles with shudder issues. Did a temp. external 10 micron filter, removed the pan and put a new filter in, filled with Amsoil. Since your out of warranty it wouldn't hurt you any to look into this option. Even if you take the car to a shop to fix...just make sure you get the trans. filter replaced and filled with Amsoil Fuel efficient signature series. Best of luck on whatever you decide for your repairs. |
06-24-2019, 09:50 AM | #20 | |
Drives: None at the moment Join Date: May 2018
Or just keep trading them in for people like me to buy them up cheap. |
06-25-2019, 11:00 AM | #21 | |
Is this something I could do at home? I have no interest in trading in this car and want to keep it running for decades to come (who knows if this is an unrealistic expectation)
06-25-2019, 12:07 PM | #22 |
Drives: 2016 Camaro SS Join Date: Sep 2018
I went with a billet unit from Circle D and never looked back, my was still even under warranty when I did it but wanted it fixed right the first time.
06-25-2019, 12:29 PM | #23 |
Smoky
Drives: 2018 1SS Join Date: Feb 2018
I live in tampa. I have my replaced stock TC. I will cut you a deal on part then get car tcm tuned. problem solved. I went with circle D and tune and now love the A8. It does suck but knowing that GM in incapable/unwilling to correctly solve issue you are at a crossroads.
06-25-2019, 01:01 PM | #24 | |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
FYI i'm now 300 miles in after having the mobil 1 fluid put in. Smooth as silk and no shudder. I guess i didn't realize how bad it was till i got the flush and new fluid. The things I thought were bumps was clearly the torque converter slipping. Will it last? Who knows but i sure hope so. |
06-25-2019, 02:52 PM | #25 | |
You can plan it to take a day and you need a pump to refill the trans fluid. (simple drill pump works). I tapped into the inter-cooler line and refilled (where I had the temp filter.) I can't advise one way or another on your ability or skill level...or even comfort of crawling around under the car on jacks... I would hate to say you "can" and just have you end up hurt or massive problems when attempting to do it. So...my official response is "youtube" a few video's. If you feel good about it then that is your call. If you choose a shop (not dealer) then make sure they use the fluid you request. I suggested the fluid as it fixed mine and I didn't have to pull the transmission on a car with 15,000 miles on it. |
