Old 06-03-2019, 02:47 AM   #15
f.d
Drives: camaro
Yes, it’s my fault.
I bought the injectors, I’m just waiting for the delivery.
Part number: 12692522
We will see what will happen, hope my car back to the normal.
Thank you for the reply.
f.d is offline   Reply With Quote
Old 06-03-2019, 04:23 AM   #16
Driski
Drives: 2016 Camaro Convertible 2SS
Originally Posted by f.d View Post
Yes, it’s my fault.
Wish you luck. Thanks for posting. I was not aware injector cleaner would be a problem.
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85
Driski is offline   Reply With Quote
Old 06-06-2019, 03:59 PM   #17
f.d
Drives: camaro
It’s happened exactly in the day i added STP,
But honestly, I putted i 500 ml for just a less than half tank.
I wanted to remove the carbon buildup, after the winter.
Any way..
I’m just waiting for the new injectors to come.
I will update
Thank you for posting and sharing
Old 06-17-2019, 09:22 AM   #18
f.d
Drives: camaro
Update
I did change the 8 injectors, the car now almost 95% perfect.
I will observe the car and oil smell situation for any leaking from the high flow pump ( GDI pump)
I think the fuel regulator is attached to the pump, I hope there’s not any problem with the fuel regulator.
I hope i did something good for camaro community and GDI engines in general.
Don’t use any fuel cleaner not recommended from the manufacturer.
Old 07-06-2019, 04:30 PM   #19
f.d
Drives: camaro
Today i did change the HPFP, the car looks running good.
I will see for the next weeks.
Old 07-09-2019, 08:01 AM   #20
f.d
Drives: camaro
Update
After changing the HPFP , fuel injectors and oil
The car runs better
on idle LTFT are: -5 % bank1 and -7 Bank2
While acceleration LTFT are: -2 % bank1 -2 bank2
When i release the throttle pedal LTFT are: -10% bank1 & -12% bank2
That’s mean the car it’s away better but still running Rich.
I’m playing to drive it for a long trip in high speed, see if it will be better.
I mean remove the carbon buildup in the cats and exhaust.
Hope i did add something good for Camaro ‘s community.
Old 07-16-2019, 05:11 AM   #21
f.d
Drives: camaro
After changing the fuel injectors and HPFP
Update, please read to the end.
After driving the Camaro for about (300 km or 200 mile) in high speed (160 - 220 km/hr) or (100 - 140 mil/hr) the car return almost to the original performance, it’s like a new car.
Response very fast.
It’s looks like very clean exhaust tips in rear end, I think the carbon buildup removed.
Note:
The numbers for the LTFT looks a way better. I did see them +1 many times, but the numbers still in negative side in usual, that is mean :
Camaro’s engine runs Rich in original situation
I think, in my opinion: things to do:
1- Cold Air intake ( a good quality) don’t buy any one suck hot air from engine’s bay. Never ever or You will get more Rich numbers. Be wise.
2- Exhaust system, removing the pipes where it’s narrow banded beside the differential , that will make more Air flow.
2- deleting 2nd cats maybe , but I don’t recommend.
Any way do not ever use STP fuel cleaner, or something not recommended.
Hope you did get some good info from this thread.
