Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 10-08-2018, 12:39 AM   #85
Pumpkin Carriage
3.6L M6 LS
Pumpkin Carriage's Avatar
Drives: 2013 Camaro LS M6
15RS2NV, I did some research on rearend gear changes when I installed 3.73 ratio in my 13LSM. The Manual was a simple ring & pinion bolt in from Yukon Gears that I took to a reliable shop. What I found in my 3.73 ratio project came down to gear selection. Local Chevy dealer says 3.73 is not available from GM. The Chevy parts guy says a ‘13 LS M6 uses same ring & pinion as the LS3 but GM only offers 3.45 or 3.91 ratios. Yukon Gears offers a YG GM3.73-IRS ring & pinion. Here’s the bad news; Your auto probably is not the same rear end & you may need to swap the pumpkin to a manual V6 or SS. They’re available, that’s what I found for my M6 & the info for the auto came up while I was researching. That’s all I got, your newer model might be different.
Pumpkin Carriage is offline   Reply With Quote
Old 06-16-2019, 12:02 PM   #86
PPV
Drives: 9C1
Rear End Gears 101
Planning to build a gen 5 differential. Are all the diff cases the same v6 vs SS ‘10-‘15 (not Zl1)? Are some stronger than others?
Sent from my iPhone using Tapatalk Pro
PPV is offline   Reply With Quote
Old 02-14-2020, 10:12 AM   #87
Pumpkin Carriage
3.6L M6 LS
It’s been a while since I’ve been to this forum. Haha. Seems like “A Long Time Ago, In a Galaxy Far, Far Away”.
What I learned & verified is that Gen 5 V-6 Manual trans models have a late version of the 10 Bold rear end ‘with’ limited slip & 3.25 to 1 gears designed for a 4 link suspension. Very Strong & suitable for a V-6 pushing up to 350hp with after market engine mods available. The Gen 5 V8 models ‘may’ have been equipped with a modern 12 bolt rear end that’s stronger than a 10 bolt. I found that where most of the challenges occur is with V6 automatic trans models because they’re not equipped with limited slip, so a simple ring & pinion swap is not going to provide what most of us want like added strength, limited slip & better gearing than the 3.25 to 1. Good luck with your swap or mods. If you have a Gen 5 automatic trans in a V6 you’ll probably find that swapping the entire axle from a standard trans model is the easiest swap method. For regearing you should recognize that stock ring & pinion are 4 cut gears & most after market are 2 cut gears, or so I was told. The regearing might provide better acceleration but expect some gear noise. Make sure to stick with Chevrolet’s recommended synthetic gear oil. The rest of what I probably don’t know about Gen 5 rear ends would, no doubt, fill many large volumes of small print. Pumpkin Carriage.
Old 02-19-2020, 06:51 PM   #88
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot A6
V6, SS and ZL1 all have different differentials, and unfortunately they are NOT interchangeable. So if you have a V6 and want to upgrade from 3.27 to something other than 3.55, you'll need to get the whole diff from the model that has your desired gears (i.e. ZL1 has 3.91)
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
15RS2NV is offline   Reply With Quote
Old 02-19-2020, 07:33 PM   #89
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 02-19-2020, 07:57 PM   #90
Pumpkin Carriage
3.6L M6 LS
@15RS2NV. Cool thing about car guys. We know metal bends, you can cut it & weld it, there are lots of options produced by aftermarket or available in junk yards. Yep, car guys will almost always find a way. We don’t often say something can’t be done because if you like building cars from scratch you probably wouldn’t mind living in an ice cold garage burning $100 bills to keep warm. You can do ‘almost’ anything, all it takes is skill, time & money. These guys on this forum are all car guys & they know what they’re doing & what they tell you is reliable. I’m bowing out as unqualified. Good luck with your car my friend.
Old 02-19-2020, 08:14 PM   #91
Chris49066SS
Drives: 2010 SS L99
The ZL1 does not come with 3.91, thats the 1LE. The ZL1 came with the 3.23 and the 3.73.
Old 06-15-2020, 10:14 PM   #92
01sleeperZ
Drives: 2015 Camaro SS VPX
I have a full diff from an SS with 3.45 gears with 45k miles that I want to sell, anyone interested? I just had the local Chevy dealer install a new Z28 diff with 3.91 gears. I also have a new rear diff cover with cooler set-up from the Z28 diff (i ended up with an uninstalled second one due to the way I ordered the parts). Both the standard SS diff and the spare Z28 diff cover are for sale.
01sleeperZ is offline   Reply With Quote
Old 06-02-2021, 04:17 AM   #93
Padres-RS
Drives: Chevy camaro rs
So I have a 2011 camaro Rs v6 automatic and want to upgrade gear ratio what do I need to do can I just buy ring and pinion and put it in or do I nees to swap out differential and I hear that I can put 3.91 and then I hear I can only put 3.55 in my car so im a little confused on what to do how is the process like a 3.55 ring and pinion would fit in my car just swap it out but if I want bigger gears I would need to swap differential the axels and all hardware or will my oem axels fit to another differential that has lets say 3.91 gears
Padres-RS is offline   Reply With Quote
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-17-2012 11:24 PM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 10:58 PM
rear end failure? xshortd Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 04-08-2010 06:59 PM
Changing rear end oil and trans oil? caverman Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 10 03-01-2010 10:09 PM
4:10 rear end or LT headers & tune? wildthing001967 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 02-06-2010 10:21 AM
