02-11-2024, 11:52 AM | #1 |
DSS drive shaft questions
Guys,
I just made some changes to the rear of my 15 SS 1LE which included Hendrix diff offset bushings and a DSS driveshaft with a Matco drive shaft loop. The car already had BMR 1.25 springs on it when I bought it. When I start the car in the shop everything seems fine but as soon as you get on the road the driveshaft is rubbing on something. The first time I tried to test drive the car I found one of the emergency brake cables had came out of its holder and cold tell that it had rubbed. But I put it back in and tried to test drive and now it’s hitting something else. Anybody have the same issue or idea what it may be hitting. Thanks |
02-11-2024, 12:17 PM | #2 |
Drives: 2013 ZL1 Join Date: Sep 2021
You should be able to see rub marks on the driveshaft.
02-11-2024, 03:22 PM | #3 |
Some of us had to remove the front heat shield, or modify it to clear the shaft..
02-11-2024, 03:51 PM | #4 |
Thanks guys, it’s the e brake cables. I had to take the back heat shield as well because it was hitting it as well. I was hoping taking that off would provide more clearance which it did. Just need to get these things tied back and I should be good to go
