dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 09-20-2023, 07:51 PM   #15
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Originally Posted by bstromback2002 View Post
I had the Hendrix bushing with the gulfcoast drive shaft and gave up on trying to keep the parking brake cables from rubbing. I’d get them up out of the way so they didn’t rub and sure enough 100 miles later they slowly worked there way back to rubbing.
If you use some decent length zip ties, you can pull the e-brake cable at the curve coming out of the tunnel towards the subframe. This will help take any slack out of the cable and help keep them in the plastic retainers on the gas tank. Hope that makes sense. If I had my car here I would take a few pics for ya.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 03-11-2024, 02:29 PM   #16
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Quick update...the driveshaft is rubbing the tank shield. It clears sitting still but there must still be enough movement under load. I really don't want to run without that shield protecting the fuel tank so I'm thinking about tossing out the offset differential bushings and just going with a set of BMR to regain some clearance. Any thoughts on that option?
Sent from my Pixel 8 Pro using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
larry_g is offline   Reply With Quote
Old 03-11-2024, 05:52 PM   #17
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
That will gain you some clearance.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 03-11-2024, 06:47 PM   #18
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
The offset diff bushings were to correct the axle angles in reference to the differential due to lowering the car. I lowered my car 1" and dont use offset bushings, but run the risk of eventually damaging my axles especially on launch when the axle angle gets more pronounced. I think you'll be fine to remove the offsets and go with a standard of your choice. My opinion so take it for what it is.
FasNuf is offline   Reply With Quote
Old 03-11-2024, 07:18 PM   #19
larry_g
larry_g's Avatar
At my power level I figure the axles are next in line to fail anyway. All in all it seems like the offset differential bushings created more problems than they solved.
Old 03-11-2024, 07:28 PM   #20
FasNuf
FasNuf's Avatar
Power is definately gonna shorten the life of any part, especially a stressed one. Sorry I didn't see if you were lowered. I think those bushings were intended for 1-1/2" and lower. I guess it really depends how much you beat on your car Larry. Then again, I don't think many of us here sit around and blow kisses at our rides.
Old 03-11-2024, 07:31 PM   #21
FasNuf
FasNuf's Avatar
Another thing you have going for you is the driveshaft is aluminum and wont get damaged rubbing the heat shield temporarily like a CF would. You have room to experiment. They do make adhesive back heat shielding that's supposed to be pretty good. That'll save you a little room.
Old 03-14-2024, 08:22 PM   #22
bstromback2002
bstromback2002's Avatar
Drives: 2010 camaro ss
Ah did you not see what a few miles and parking brake cables did to mine from gulfcoast driveshaft video?
But I pulled all my heat shields and did the adhesive backed heat shielding on my tank.
bstromback2002 is offline   Reply With Quote
Old 03-15-2024, 09:12 AM   #23
larry_g
larry_g's Avatar
BMR bushings should be here today and may even get installed this weekend.
Old 03-15-2024, 10:43 AM   #24
FasNuf
FasNuf's Avatar
Even temporarily for a few miles it was damaged? crazy. How many miles were you driving on that? I was thinking that you'd be able to hear it and fix pretty much right away. CF wouldnt let you rub on it at all before tearing into the carbon.
Old 03-15-2024, 12:12 PM   #25
bstromback2002
Wasn’t more than a mile or so and it left a light groove. He was able to polish it out though.
Old 03-15-2024, 01:00 PM   #26
FasNuf
FasNuf's Avatar
[QUOTE=bstromback2002;11411652]Wasn’t more than a mile or so and it left a light groove. He was able to polish it out though.
Wow! I wouldnt expect that. Thanks for letting me know. Cant imagine the damage it couldve caused the Cf. Probably unrepairable.
Old 03-17-2024, 07:17 PM   #27
larry_g
larry_g's Avatar
BMR bushings installed. We'll see how it goes but my initial impression is that they are much stiffer material than the offset bushings and will hopefully keep the driveshaft from hitting under load. No real difference in NVH and, if anything, the additional driveshaft angle reduced vibration.
