Old 05-25-2022, 02:36 PM   #15
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
Ive been running the TSP headers for the last 6 or so years. Zero fitment issues. Still look great. They are another option if you are trying to save some coin
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads
Arogg is offline   Reply With Quote
Old 05-25-2022, 06:39 PM   #16
RS/SS '10
Drives: 2010 2SS/RS
Originally Posted by Royal Tiger View Post
I find it more true than not from everything from car parts to electronics to firearms. Sure cheap stuff works, but again it costs more for a reason. Better materials, better fit & finish, etc…. Looking at speed engineering than AR or Kooks you can see why one costs more.
I completely agree with the above statement. In my build I could have used less expensive parts, pretty much everything I have bought there were cheaper alternatives, but the statement from Royal Purple is the way I see things.
When I got serious about buying headers I started with Kooks, plus the green cats. I also added in the price of getting them ceramic coated, which I think was a smart move. I looked at a lot of headers, but within seconds to a very few minutes I always went back to the Kooks. Now, I am not kicking anyone else's decisions, we all have our own ideas and thoughts.
I do have a question about the headers with the heat tape on them. Were they chromed or stainless steel?
RS/SS '10 is offline   Reply With Quote
Old 05-25-2022, 08:13 PM   #17
Royal Tiger
Purple?
Old 05-25-2022, 08:38 PM   #18
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
I do have a question about the headers with the heat tape on them. Were they chromed or stainless steel?[/QUOTE]
The Speed Engineering headers are 304 Stainless. The wrap isn't a tape but just a wrap made by DEI. They make it from different materials depending what you want.
Here's my video on keeping the ends from fraying. DEI Titanium
https://youtu.be/mkhnI-1j_yY
FasNuf is offline   Reply With Quote
Old 05-25-2022, 08:50 PM   #19
RS/SS '10
Drives: 2010 2SS/RS
Purple, too damn funny. My bad on the tape-wrap, so the wrap made them the color they are now, or do all of those headers end up looking like that? With the ceramic coating that Kooks use I have no need for the wrap. I am planning on using some of their gold wrap in other places.
Old 05-27-2022, 11:03 PM   #20
TooleyOnDeck
Tooley
TooleyOnDeck's Avatar
Drives: '18 2SS 1LE
For anyone currently considering these, I ordered and installed mine this week (late May 2022) and here’s the rundown:
The finish was decent, there were a few visible scratches and burrs but they were overall fine. Reports on fitment vary, but on mine the passenger side header hit my subframe during test fit, so I marked the spot under the car and dimpled the header about 1/4” x 2” to clear it and it went back in perfectly (2015 1SS L99).
The SE clamps are 💩 so reuse your OEM rear clamps and get some 3” flat band clamps from your local part store. I torqued down the SE clamps as far as I could with an impact and still had leaks. So I put some tiger patch across the off road connector and the header and clamped over it and no more leak. I also used ARP header bolts in lieu of the supplied bolts. The SE MLS gaskets worked fine. I’m currently using Taylor 409 10.4mm wires (180° boot) and they clear the headers fine, none of them touch.
The SE headers are supposedly slightly thinner walled than ARH or Kooks, and I can confirm you get a bit more of a “tinny” sound afterwards. Plan your exhaust system to account for that, mine is OEM to the axles and I currently have 2 rear mounted Magnaflows but I don’t really like them so I’m currently looking into other options.
My final thoughts are that these are a good option for the budget-conscious enthusiast. I had my Camaro tuned by DynoSteve and I’ll be going next week to do some dyno runs to compare to my stock baseline, so I’ll make a post afterwards for those considering DSP remote tuning as well. 👌🏼
2018 Camaro 2SS 1LE | Red Hot | PDR
2015 Camaro 1SS/RS | Black | FBO, Tuned (SOLD)
TooleyOnDeck is offline   Reply With Quote
Old 05-27-2022, 11:11 PM   #21
FasNuf
FasNuf's Avatar
I agree with Tooley. The clamps and head hardware were junk. I think I bought Fleetrite exhaust clamps from Fleetpride. Nice and wide and they sealed well. The head hardware I used was from Stage8 and was made from Chromemoly. Not sure why I didn't go ARP, probably because I liked the positive locking system Stage8 had. Works great and no leaks, but a little tricky to install and I hope I never have to remove them.
Old 05-28-2022, 07:12 AM   #22
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Purple?
haha what's up Royal Purple.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is online now   Reply With Quote
Old 05-28-2022, 08:35 AM   #23
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
This is about as fair of an assessment as you can get. Thanks for sharing your experience.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 05-28-2022, 08:44 AM   #24
Shodown
Shodown's Avatar
Drives: 2014 ZL1
I have 1-7/8 Speed Engineering headers on my ZL1. No fitment issues whatsoever. Yes the clamps are crap, but get yourself some lap joint band clamps from Summit or Jegs and you'll be golden.
With the $1000 I saved not buying Kooks or ARH I got a Killer Chiller. Worth every penny saved.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
Shodown is offline   Reply With Quote
Old 05-28-2022, 10:33 AM   #25
Royal Tiger
I think that is a screen name on here. Lol
Old 05-28-2022, 07:55 PM   #26
TooleyOnDeck
Tooley
Drives: '18 2SS 1LE
Thanks, and no problem. I figured this thread would come up before any new thread I could make, and many out there probably run into the same love/hate reviews that don’t really benefit a person making a decision.
Old 05-28-2022, 08:04 PM   #27
FasNuf
FasNuf's Avatar
I haven't heard anyone say they hated the SP headers, only that some liked spending more for more quality. I guess it just depends on what you're trying to accomplish with your budget and if you're willing to gamble a little that they fit.
headers
