01-23-2019, 09:38 AM | #15 |
Drives: 2018 SS 1LE Join Date: May 2018
I’m absolutely ok being wrong... the issue is that #1 I’d like to see a bolt on graph with the stock manifold vs MSD only. No heads, cam or other added items
Also posts from guys like you are exactly why most forums are full of trash comments and not worth sifting through to dig up factual content so I’ve asked Pray to clarify and even shoot me a PM with those graphs so I don’t have to see your Barbie comments
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
01-23-2019, 10:01 AM | #16 | |
2016 NFG 1SS A8
01-23-2019, 10:08 AM | #17 | |
I wasn’t rude at all in posting yet received some kid like responses so you felt the need to be that guy and now you don’t like the response? Your interpretation of Lazy is whatever benefits you so why don’t you just stop responding without benefiting the question I asked. Do you have a good Bolt on Dyno graph with the only change being a stock intake manifold compared to the MSD? AND just for the record... I was not wrong to say gains are to be had going from the stock manifold to the MSD.
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl Last edited by JonD; 01-23-2019 at 01:48 PM. |
01-23-2019, 10:12 AM | #18 | |
Drives: 2016 2SS Join Date: Jul 2016
My last comment was that you will see gains up top over stock. No doubt. But what will they gain you in the 1/4 over stock is the question I can't answer. Top end gains don't always translate our to E.T. especially on a stock converter since the MSD loses a bit down low. You will gain mph though. I always have budget in mind since these cars are so costly to modify. I always try to present the options and what you will gain for the money laid out. I took from your post that budget may be a concern. My illustration was meant to demonstrate the marginal gains for the price. And to show what the other mods required to make it viable. So I took the best case scenario with ported heads and converter to make the MSD shine. It just didn't happen. At this point I have not back to backed stock IM/TB to stock MSD at the track. But ported to ported should be the same comparison. It is unanimously agreed upon that the MSD needs porting out of the box. And the stock TB needs to be ported to accommodate the higher airflow demands of the MSD. Or to do it right, a ported 95mm. I don't have the time either to post everything from the past to make a point. So I went with the simplest, quickest comparison I had on hand to answer what I thought was your question. Buddy was a term of endearment, not an insult.
01-23-2019, 10:17 AM | #19 | |
I have a hand ported 95mm TB in my cart so would you recommend getting the MSD ported or would that cost not really benefit me as I’m not going to be opening up my motor anytime soon?
01-23-2019, 10:21 AM | #20 | |
Yes, porting the manifold is worth 10-15rw on bolt on cars. I have indipendant testing as high as 23rw from just porting the MSD on a bolt on car. It also greatly reduced the tq loss down low. That number was proven out on the street to be legit. Two of my customers raced on the street multiple times with the ported MSD coming out 2+ cars every time. Once the porting was complete to both cars it was like one car length or less in multiple back up races.
01-23-2019, 10:23 AM | #21 | |
01-23-2019, 10:29 AM | #22 |
NP.
01-23-2019, 10:36 AM | #23 | |
It was just a joke...quit taking the internet so serious. Pray does on his Facebook page.
2016 NFG 1SS A8
01-24-2019, 12:45 PM | #24 |
Drives: Camaro Join Date: Sep 2018
I have a 95mm TB but just can't pull the trigger on the black lettering MSD IM.
Does this need a tune after install? |
01-24-2019, 12:49 PM | #25 |
Does not need a tune. If you have a auto the car is begging for a tune. Get hptuners
01-24-2019, 01:15 PM | #26 |
I have a hard time paying that price with 8 credits & pay each time I need a different tune, really starts to add up. Right now I'm just trying to put bolt-ons that do not need a tune. I have some Kooks 1-7/8 headers with hi-flow cats that I've had for 6 months now, but to afraid to put them on because if I get some CEL's I'm going to go crazy...
01-24-2019, 01:20 PM | #27 | |
01-24-2019, 03:19 PM | #28 | |
2016 NFG 1SS A8
