01-20-2019, 01:29 AM | #1 |
SS
Drives: 2018 ss Join Date: Mar 2018
Mad intake manifold with ported throttle body
So I plan as part of my build to add an msd atomic intake manifold but buying a ported throttle body I've been told it ain't recommended by certain shops around me . For anyone with experience with this. is it really worth getting or just doing msd atomic manifold only? Throttle bodys are pretty expensive so i don't wanna waste 300$+on nothing. Thanks in advance
01-21-2019, 11:05 AM | #2 | |
Moderator.ca
I hope you get some answers to you question. -DG
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
01-21-2019, 11:11 AM | #3 |
Drives: 2018 SS 1LE Join Date: May 2018
I’m on the fence with this as well...
For the $ I’m going to gamble on the MSD IM & the Tick performance modded GM 95mm TB. No adapter
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
01-21-2019, 12:04 PM | #4 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
This topic is discussed at some length here, in case you haven't seen it already. https://www.camaro6.com/forums/showthread.php?t=535959
01-21-2019, 01:21 PM | #5 |
I would do the tick combo with the 95mm
01-22-2019, 10:40 AM | #6 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
I have the MSD and 95mm ported TB combo from Pray Performance... 100% worth it.
I would get it and look for another shop too, they obviously have no experience with 6th gen if they are willing to say that. 6th gens have been out for over 3 years already with tons and tons of data and comparisons proving they are worth it.
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
01-22-2019, 11:05 AM | #7 |
Pray just had a bolt-on only M6 car with his ported stock IM/TB combo run 10.85 @ 126. I am not convinced the MSD does anything for a bolt-on car in the 1/4mi. Perhaps for roll racing events it has a slight edge. Heads/cam combos do benefit from the ported MSD/95.
2016 NFG 1SS A8
01-22-2019, 11:23 AM | #8 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
i run a ported msd intake manifold and ported throttle body, i have no complaints
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
01-22-2019, 11:25 AM | #9 |
Just look at a bolt on car dyno where the HP dumps up top and compare it to a bolt-on car that has at least the MSD as the HP doesn’t fall off. I’d say that’s big time usable power that will translate to much better time and the all mighty Butt-Dyno
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl Last edited by JonD; 01-22-2019 at 01:34 PM. |
01-22-2019, 01:46 PM | #10 | ||
@Blackmamba_1LE
01-22-2019, 05:59 PM | #11 | |
Drives: 2016 2SS Join Date: Jul 2016
01-23-2019, 08:38 AM | #12 |
Class is dismissed.
2016 NFG 1SS A8
01-23-2019, 08:57 AM | #13 | |
Help me understand what you’re saying as No I do not search the forums for past threads like some people with endless time. That’s cute, I fully expect flack on stuff so he can answer questions without bandwagon support as it’s clearly not needed with his history
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl Last edited by JonD; 01-23-2019 at 09:20 AM. |
01-23-2019, 09:35 AM | #14 |
It's ok to be wrong sweetie.
2016 NFG 1SS A8
