09-15-2018, 01:40 PM | #1 |
Drives: 2016 2SS Join Date: Mar 2012
Hood not even?
Just purchased a 2016 2SS with 10,000 Miles.
Does my hood alignment look off? |
09-15-2018, 01:54 PM | #2 |
Drives: 2017 2ss, m6 Join Date: Jan 2017
I really cant tell with the round roll of tape on it.
09-15-2018, 02:04 PM | #3 |
Tried to give a perspective with the tape. Here’s other shots.
09-15-2018, 02:21 PM | #4 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
Simple fix, Adjust it. Fairly common issue.
Just take your time and make small adjustments till it's correct. |
09-15-2018, 03:44 PM | #5 |
Drives: 2018 ZL1 1LE / Nightfall Grey Join Date: Apr 2013
I had a issue where the hood would not close when you dropped it for about a foot from close - it was the little round hood stoppers, I think they just turn by hand and you can adjust the height of the hood like you want ( I think)
Ps how do you add images to the darn forum - I have a image for the, but I just get a URL option to add it 0 how can you upload one? |
09-15-2018, 06:04 PM | #6 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Sometimes when you adjust up the hood stoppers, the hood won't latch. I had to raise the latch mechanism a bit to get it to latch and be even.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
09-15-2018, 06:45 PM | #7 |
My trunk was not aligned. There are two screws to adjust it up and down. I'm assuming there is something like that for the hood
09-15-2018, 07:30 PM | #8 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
That hood edge along the front bumper cover and both front fenders is easily adjustable. There are adjustable stops and the enclosure plate when you open the hood is adjustable also. A good body guy can fix that in 15 minutes
09-16-2018, 03:13 AM | #9 |
Drives: 2017 ZL1 - Hyper Blue Join Date: Mar 2015
There are 2 torx head bolts in the radiator support/cover, 1 on either side of the hood latch. Those adjust the height of the front bumper cover. I had the same issue and some others on here have as well. My guess is that'll fix your problem. Check this write up for details and pictures.
https://sandyblogs.com/techlink/?p=5622 Sent from my Pixel 2 XL using Tapatalk |
09-16-2018, 07:47 AM | #10 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Yes, the alignment is off. I'm not sure what the actual spec is but it should be around +/- 1 or 1.5 mm for general body panel fits and you look way over that.
First of all, is the car still under warranty? If so have someone who knows what they are doing make the adjustment. If not, you've been provided some good information on making the adjustment yourself. Good luck!
09-16-2018, 09:32 AM | #11 |
That happened on my 2013 too. Good to know it's adjustable.
