01-26-2018, 05:32 PM | #1 |
Drives: 2016 2SS Camaro fully loaded. Join Date: Nov 2016
Fix-a-flat, etc destroys TPMS?
Is this true? I was told if you have a flat (on non-run flats obviously) and use something like fix-a-flat to patch the tire, it will destroy the TPMS for that wheel. And those are NOT a cheap replacement.
01-26-2018, 05:38 PM | #2 |
Retired from Car mfrs....
01-26-2018, 05:43 PM | #3 |
Thanks, looks like I should throw a bottle of this in the trunk then!
01-26-2018, 08:38 PM | #4 |
Scenic City Camaro
Drives: 2022 Camaro ZL-1 /1974 Firebird 400 Join Date: Jan 2014
They certainly put some thought into it
2017 Camaro 2SS
2022 Camaro ZL-1, grey
1974 Firebird Formula 400, white https://www.facebook.com/groups/Camaro/ https://www.facebook.com/CRFinTN/?modal=admin_todo_tour |
01-27-2018, 06:56 AM | #5 | |
Drives: Too many to list Join Date: Dec 2011
1) Check the packaging of any tire sealant you use. Some are specifically formulated to se safe for TPMS sensors 2) TPMS sensors are not overly expensive. You can get 4 for around $50-60. Sent from my iPhone using Tapatalk Pro |
