Old 05-29-2009, 11:30 AM   #1
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Camaro straight pipe, a quick and easy exhaust mod (videos)
Hey there Camaro5 members. If you are a little tight on the finances but want to help out your exhaust sound and power. You Tube links to a 200.00 quick and easy exhaust mod (where stock mufflers are removed and replaced with straight pipe). Why are some spending the big bucks when you can do this? Thanks to Hylton for posting these up for me.
Negotiated price for Camaro 5 Members 200.00 installed. Colorado only but just about anyone can do this if they take their time to get the proper allignment and angles. Fabricated and installed by Exhaust Pros of Commerce City Colorado 303 287-9669. Dont forget to tell them you are a Camaro 5 member
start up
easy drive off
normal drive by
getting on it drive by
Getting on it drive off with trac control still on.
close up of pipe
additional shots of pipes
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 05-29-2009, 11:34 AM   #2
King Mouse
King Mouse's Avatar
Drives: EXT
That sounds nice. Just takem' out?
King Mouse is offline   Reply With Quote
Old 05-29-2009, 11:37 AM   #3
nards444
nards444's Avatar
Drives: 1SS/RS Black
so they just took the mufflers off. Is there a DIY instructions out there. Will this mess up the computer. To me it sounds like its still muffled by something is that Cat? Also does this car have true duals or is it a H pipe
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
nards444 is offline   Reply With Quote
Old 05-29-2009, 11:39 AM   #4
Bawt
Future Camaro Owner!
Bawt's Avatar
Drives: 2010 Mustang GT soon
Sounds.... Awesome!
I'm super impressed!
Bawt is offline   Reply With Quote
Old 05-29-2009, 11:42 AM   #5
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
I just love how you can now see the IRS with those jerry cans removed. Great mod for looks and sound!
"BBOMG - More than just a car show.... It's an experience!"
Hylton is offline   Reply With Quote
Old 05-29-2009, 11:42 AM   #6
MadMaxx
Master of the V6
MadMaxx's Avatar
Drives: 2010 Camaro 1LT/RS
Yes, they just gutted the muffler with a strait through pipe. DIY would just be cut the muffler off, slip on this section and tack weld it on.
It won't affect computer -- nothing back past the cats are monitored. LS/LT/SS cars all have true duel exhaust w/ an X-pipe. And yes, the cats (2 per bank, 4 total) do muffle the car a bit.
MadMaxx is offline   Reply With Quote
Old 05-29-2009, 11:53 AM   #7
2010 SS RS
2010 SS RS's Avatar
As featured on homepage.
Here is some more;
Deceleration to idle
Idle
Right side with independent rear visable.
Old 05-29-2009, 12:00 PM   #8
The Dark Knight
Batmobile in Disguise
The Dark Knight's Avatar
Drives: 2009 Pontiac G8
Will it pass smog?
The Dark Knight is offline   Reply With Quote
Old 05-29-2009, 12:02 PM   #9
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Originally Posted by TheDarkKnight_23 View Post
Will it pass smog?
Sure, just tell them you have inline mufflers. It's the latest technology out there and the Camaro is the first car to have it available as an option.
rolnslo is offline   Reply With Quote
Old 05-29-2009, 12:02 PM   #10
2010 SS RS
2010 SS RS's Avatar
Will it pass smog?
Every state is different. But as long as you dont touch the cats there is no effect on the smog. Some areas have local ordinances regarding mufflers but then again I am not putting on my front license plate either.
Old 05-29-2009, 12:02 PM   #11
Hylton
Hylton's Avatar
Will it pass smog?
Absolutely! Everything in front of the rear axle is left intact.
Old 05-29-2009, 12:06 PM   #12
2010 SS RS
2010 SS RS's Avatar
Perfect response.
Old 05-29-2009, 12:07 PM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Cool I think! It could only be better, for the money, if the pipes were mandrel-bent and stainless (they didn't look stainless anyways). I think the only muffling left are the resonators. It sounds pretty good!
'20 ZL1 Black "Fury"
Old 05-29-2009, 12:39 PM   #14
GTAwheelman
Drives: 1985 Camaro Sport Coupe
on start up and idle it sounds just like my truck. not that that is a bad thing.
i have a 2001 silverado with the 4.8 LR4(iron cousin of the LS engines) and the exhaust dumps right after the cat. it was suppose to be a temp fix, that was 2years ago.
GTAwheelman is offline   Reply With Quote
Answeres to questions I have stumbled on dieseldave24v 5th Gen Camaro SS LS LT General Discussions 13 02-23-2009 06:56 PM
UPCOMING CAMARO IMPORTANT DATES CamaroScotty 5th Gen Camaro SS LS LT General Discussions 125 01-11-2009 12:31 AM
