Roto-Fab
Old 10-21-2019, 12:24 PM   #1
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
PRC 260 PTV clearance with huge solid roller cam?
Anyone got a huge cam with PRC heads 255-260 heads?
I'd get them with 67-66 cc chambers.
I want to run a solid roller llsr like 244 / 257 with around 670 lift.
I was planning to run ported LS3 heads and flycut but I might want to not flycut so looking at custom heads and looking for 11.0-11.2:1 compression.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 10-21-2019, 01:48 PM   #2
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Mine were 65cc. Milled them .035" to get around 60cc for 12:1
I run a 243/255 hyd. and had to flycut.
Bo White is offline   Reply With Quote
Old 10-21-2019, 02:06 PM   #3
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Thanks
Did you flycut much?
A solid would be like 240 253 and I wouldn't mill cause I run on 91oct...
Any update on your times?
13' 1LE
Old 10-21-2019, 04:55 PM   #4
CFD
Drives: 2SS/RS L99 BLACK
My stock heads were 64.5 cc with Manley valves.
CFD is offline   Reply With Quote
Old 10-21-2019, 09:37 PM   #5
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Soo stock LS3 heads milled and what cam? Not PRC custom?
..or just a solid roller ?
13' 1LE
Old 10-21-2019, 09:44 PM   #6
CFD
Stock LS3, not milled.
Old 10-22-2019, 01:41 AM   #7
Bo White
Bo White's Avatar
I flycut the pistons .100" just because
I run pump 93 but keep timing at 24*
Old 01-16-2020, 10:09 AM   #8
IWANTA(ss)
IWANTA(ss)'s Avatar
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14
I have a question for you. What’s harder fly cutting the pistons or a full cam install on a LS3 down to the oil pump?
02 Stepside Silverado
05 ZX-10
13 1LE
14 Nightrod Special
IWANTA(ss) is offline   Reply With Quote
Old 01-16-2020, 10:59 PM   #9
Blakester
Drives: 2010 1ss
What fly cutters are guys using?
Blakester is offline   Reply With Quote
Old 01-17-2020, 11:33 AM   #10
Bo White
Bo White's Avatar
Fly cutting isnt hard just time consuming
Old 01-19-2020, 05:41 PM   #11
Blakester
Drives: 2010 1ss
Bo care to share which cutters you used? I've looked at the isky ones and they dont appear too have proper sizes. Unless I'm looking wrong.
Old 01-19-2020, 07:55 PM   #12
CFD
I use cutters from Lindy Tools.
Old 01-20-2020, 06:14 AM   #13
Bo White
Bo White's Avatar
I second Lindy
Old 01-20-2020, 06:38 PM   #14
Blakester
Drives: 2010 1ss
Thanks!
