10-04-2009, 06:47 PM | #15 |
Drives: 95 bbb impala ss Join Date: Apr 2009
with the car in park or withe the brake on you go through the menu in the dic to vehicle information then select the tire pressure screen then you hit the clear/reset button on the end of the turn signal stalk then the horn will bloww twice then it will relearn
10-04-2009, 07:37 PM | #16 | |
Drives: 2010 Camaro Join Date: Mar 2008
Guess I'll go and check the pressure with my One-Shot Tire Inflater http:www.microfiberplus.com/tires.htm |
10-04-2009, 08:34 PM | #17 | |
Drives: 2016 & 1967 Camaro, 2015 Impala, +1 Join Date: Jul 2009
It sounds very intresting. I guess you paid about $25. for it ? |
10-04-2009, 10:51 PM | #18 | |
when the tire pressure reaches same. Also, the DIC reports same. Yea-- I pd. $24.95 plus $8.00 S/H for a total of $ 32.95. |
10-05-2009, 12:41 AM | #19 |
keep in mind when you drive the tires will INCREASE a few pounds, so i would say drive around for 10 minutes, get the tires warmed up, not doing burn outs mind you, and then check the readings, add accordingly.
10-05-2009, 01:06 AM | #20 |
SoCal C5 Family Member
Per the Owners Manual "Tire pressure should be checked when your tires are cold."
1LT RS Auto SIM Gray C&C BA, JBA Axle Back
1100: 5/8/09 | 3000: 5/27/09 | TPW: 7/13/09 3800: 7/22/09 VIN 126623 4200: 7/24/09 | 6000: 8/6/09 |
10-05-2009, 08:48 AM | #21 | |
Yes you set the pressure when cold ( BEFORE you drive the car) !!!! That goes for any car, All listed tire pressures are set before you drive the car (COLD) or after the car sits for at least 1 Hr. Yes the pressure goes up after you drive it. That is the way it is meant to be. |
10-05-2009, 08:53 AM | #22 | |
PS.. the 19" or RS 20" tires are rated at 50 lbs. max. Last edited by 97one; 10-05-2009 at 09:01 AM. Reason: add PS |
10-07-2009, 11:14 PM | #23 |
true, read them cold, then read them hot, then add accordingly
10-08-2009, 07:34 AM | #24 |
10-11-2009, 04:46 PM | #25 |
Institutionally Insane
Tires must be filled cold. To get a baseline, check first thing in the morning. I filled mine up 3 weeks ago to 36 psi, then checked again this morning and they were 32 psi.
Why? Ambient temps here have dropped 20-30 degrees since. You must check your pressures every two weeks to maintain the pressures, especially when temps rise or drop significantly. I have mine at 36 psi and have remained steady with no fluctuations since the ambient temps have stabilized. If there are no leaks in the tire, 36 psi cold in June equates to 30-32 psi cold in October. Physics...
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Tire Pressure Problems | Matster | Canada | 14 | 10-03-2009 06:11 AM |
Tire Pressure Monitoring | Dentyneice | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 08-14-2009 06:42 AM |
How does onstar know what tire pressure I have? | FLYNNZL1 | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 08-09-2009 02:11 PM |
Resetting TPMS Tire Pressure System | jvmax | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 07-10-2009 12:37 AM |
Tire Pressure | toehead93 | Dragstrip and Launch Techniques Discussion | 4 | 06-09-2009 12:24 PM |
