10-04-2009, 04:25 PM | #1 |
Drives: 2010 Camaro Join Date: Mar 2008
Tire Pressure ?? WT( Heck )
On Star informs me that my tires are in need of some Air Pressure.
The LF-31, RF-31, LR-32, RR-32. Three weeks ago I had put 36 lbs in each of the tires. Ok, so now my wife and I go out to the garage and proceed to put air into the drivers side front tire. (Remember, it's at 31 lbs) She is looking at the Information Screen and tells me that the passenger side air pressure is going up to 34 lbs. I told her that it can't be, because I'm on the drivers side. She said OK, but the passenger side air pressure is going up on the screen. I continue to put more air in the tire and she tells me that the passenger side now shows to be at 36 lbs. WHAT THE HECK! I now go to the rear drivers side, which is at 32 lbs and I proceed to start putting air into that tire. My wife then tells me that the screen is showing that the rear passenger side is starting to show an increase in air pressure (which is the opposite side that I'm putting air in). I then started putting air in the tires on the passenger side and the air pressure showed to be increasing on the drivers side, according to the information screen. Well, I did finally put 36 lbs in all of my tires, but is anyone out there having the same problem, and if so, what did you do to correct it? (I'll probably end up going to the dealership). These are the factory tires that came with my 2LT/RS. |
10-04-2009, 05:15 PM | #2 |
Thx-- But why is it reporting pressure for a tire on the opposite side?
10-04-2009, 05:18 PM | #3 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
Sensors are confused on which position they are in?
10-04-2009, 05:19 PM | #4 |
Have the dealer reprogram it, it sounds like someone rotated your tires.
10-04-2009, 05:21 PM | #5 |
2LT/RS... no rotating... or at least you are not supposed to...
10-04-2009, 05:59 PM | #6 |
Hey, That's right! I've got 10,000 miles on the car already, so OnStar, 2000 miles ago, informed me to rotate the tires. But because I've got larger tires on the back, Discount Tire rotated them side to side. Maybe that's why I'm getting a mixed up reading. I guess I'll be taking it back to the dealer to get it reprogrammed. Thanks for your help guys!
10-04-2009, 06:10 PM | #7 |
Is it 245 in front and 275 in back on RS?
2010 1LT/RS CAMARO #45387 - NMGGH6 - V6/M6 - AQUA BLUE METALLIC, BEIGE INTERIOR, C&C PACKAGE
1100 : 10/06/2009 2000 : 08/10 2500 : 08/11 3000 : 08/11 TPW 09/07 3100 : 08/24 3300 : 08/24 3400 : 09/01 3800 : 09/14 - 2G1FF1EV1A9145387 4000 : 09/11 4200 : 09/16 4200 : 09/23 |
10-04-2009, 06:14 PM | #8 | |
Drives: 2020 Cadillac CT5 V and 87 Buick GN Join Date: Dec 2008
2SS, Nightfall Gray, A8, MRC, NPP, NAV, Blk Bowties
Gen 6 1100 01-22-2016 2000 03-22-2016 3000 03-25-2016 TPW 4/11 3400 04-01-2016 3800 04-08-2016 - Built 4200 04-08-2016 6000 04-20-2016 Gen 5 1100 04-22-2009 2000 05-15-2009 2500 05-19-2009 3000 05-21-2009 3400 06-10-2009 3800 06-18-2009 4150 06-18-2009 4200 06-19-2009 4800 06-29-2009 4B00 06-30-2009 5000 07-10-2009!!! |
10-04-2009, 06:20 PM | #9 | |
Drives: 2016 & 1967 Camaro, 2015 Impala, +1 Join Date: Jul 2009
See pg. 9-60 in the manual. It tells you how to do it by increasing or decreasing the tires air pressure. |
10-04-2009, 06:24 PM | #10 | |
10-04-2009, 06:24 PM | #11 |
10-04-2009, 06:29 PM | #12 |
10-04-2009, 06:29 PM | #13 |
10-04-2009, 06:31 PM | #14 |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Tire Pressure Problems | Matster | Canada | 14 | 10-03-2009 06:11 AM |
Tire Pressure Monitoring | Dentyneice | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 08-14-2009 06:42 AM |
How does onstar know what tire pressure I have? | FLYNNZL1 | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 08-09-2009 02:11 PM |
Resetting TPMS Tire Pressure System | jvmax | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 07-10-2009 12:37 AM |
Tire Pressure | toehead93 | Dragstrip and Launch Techniques Discussion | 4 | 06-09-2009 12:24 PM |
