Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-14-2014, 04:22 PM   #1
jalloor
Drives: 2014 black zl1
slow 2014 lingenfelter stage 2 ZL1
Hi everyone,
i'm a new ZL1 owner, i purchased the car in November of 2013 as a 2014(6spd) model.
I just installed a stage 2 Lingenfelter kit and tune (650hp) to help improve the acceleration but the car is not performing like i think it should at the drag strip. I know it is not a drag car but that should not be a reason why it cannot perform reasonably well. I suspect the car might have something wrong with it.
My quarter mile times are 12.5 at best with a trap speed of 114mph - 109mph with the stage 2 kit installed, on a cool day(64 degrees fahrenheit). Launch control causes violent wheel hop on the track so i do not use it, and the best times were achieved from traction control fully off with a mild launch at 1500rpm.
For comparison sake, my friends 2009 CTS-V manual ran consistent low 12's and a best of 11.98 at 119mph on the same day.
My dyno results before the install read 445hp on a dynotech dyno which accounts for 30% drivetrain loss. I gained 67hp with the install to a total output of 512hp, and a rich air to fuel mixture! The car is running pretty rich on acceleration.
I followed the recommended break in period as stated by Chevrolet for 1500miles.
At this point i'm clueless on what to do. I even tried resetting the ECM as stated by some and it feels faster but i guess i'll have to go back to the strip on a cool day to see if my time better or get it dynoed again to check the air to fuel mixture and power reading.
Any suggestions are highly welcome please. I hope that someone on this site with a ZL1 might have had the same issues solved.
jalloor is offline   Reply With Quote
Old 05-14-2014, 04:30 PM   #2
HDRDTD
A stock ZL1 M6 should dyno right around 490-500 rwhp.
Who installed the stage 2 kit and who tuned it after?
Old 05-14-2014, 05:09 PM   #3
hognutz
hognutz's Avatar
Drives: 2013 ZL1
car is way down on power unless that is a heartbreaker dyno. you are working with 22% drivtrain loss by you numbers.
you should be at literely like 575-585 whp. do you have any datalogs is the cars IAT2's high or any knock?
I would have the car retuned.
shopping for 2017+1le or zl1
2009 CTS-V -sold
2015 Hellcat-sold
2013 ZL1 -sold
2007 Z06- sold
2014 Chrysler 300
2011 Duramax 8" lift, deleted tuned
hognutz is offline   Reply With Quote
Old 05-14-2014, 05:12 PM   #4
cam99
cam99's Avatar
Drives: 2012 ZL1
Lots of factors go into et's, but trap speed is usually a little easier to nail down. I agree it seems a bit low. What's included in the stage two kit? i'm assuming a pulley and cai and tune. If it's running very rich that's not helping things. Are you racing on stock tires, and are you letting it cool off between passes or hotlapping? I lose about a tenth and a mph each hot lap I run. It will pull timing pretty hateful if it's not cooled off between runs. Is the tune some canned one from lingenfelter, or was it custom tuned? Sounds like tune trouble
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 05-14-2014, 08:38 PM   #5
jalloor
it is a canned tune from lingenfelter. The stage 2 includes injectors 63lbs, cold air intake, 2.55 pulley, and crank overdrive. i contacted lingelfelter about the tune and sent them data logs they said that the tuner is on vacation until the 28th i'll have to wait until then.
Old 05-14-2014, 08:41 PM   #6
jalloor
i have data logged the car twice at the strip and these are on the first passes. Everything looks good on the scanner.
Old 05-14-2014, 08:41 PM   #7
jalloor
a performance shop installed the kit and the lingenfelter tune.
Old 05-14-2014, 11:19 PM   #8
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Yes your power is down.....first time i ever went to the track, no tune, Roto-Fab, and cat back...12.8 @ 113mph that was my best time out of three...so yes your power is down!!
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 05-15-2014, 03:46 AM   #9
13ZL1BLove
Drives: 2013 Camaro ZL1
I have a roto fab, ported v max, muffler delete, no tune and my best time is a 12.3. So yeah your power is way down with a stage 2 install.
2013 Summit White ZL1
13ZL1BLove is offline   Reply With Quote
Old 05-15-2014, 06:33 AM   #10
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
my tuner flies to Indiana to resolve these tuning issues at Lingenfelter. He does mail order tunes and can get you straight. Check out my sig.
Old 05-15-2014, 01:49 PM   #11
hognutz
hognutz's Avatar
Drives: 2013 ZL1
what were your IAT2's by the end of the run. I think it starts to pull timing at 138 degrees if my memory serves me correctly. Something seems off on paper. that MPH is retarded low. even if you 60' sucks or you spin off the line you trap speed should still somewhat represent you power level.
if you tune is fat that needs to be corrected. IMO saying they can't tune your car for two weeks is pretty lame. I would contact ted jannety or one of the other vendors see if you would have him look at the datalogs.
maybe buy a part from him or somethign for his time. I can't understand how a company as big as lingenfelter can have no tuning on site for 2weeks that is crazy.
2009 CTS-V -sold
2015 Hellcat-sold
2013 ZL1 -sold
2007 Z06- sold
2014 Chrysler 300
Old 05-15-2014, 05:34 PM   #12
jalloor
The tune is being returned to lingenfelter! The car is being dropped of first thing monday morning. Mean while, i have pictures and dyno run videos i took today. You will see how the torque takes a big dive in the early stages before climbing up. That explains why the car feels sluggish down in the low rpms. The numbers you see are based on a dynotech dyno which reads significantly low.
The car dumps fuel well of the charts that the sensor can read hence the straight line on the air/fuel graph.
Old 05-15-2014, 05:40 PM   #13
jalloor
I did not check what my IAT's where after the run. I'll have to find out this weekend. I'll send the guy you recommend my data logs but i first want to try a different tuner on monday.
Old 05-15-2014, 05:46 PM   #14
jalloor
I will call again tomorrow. Thanks.
quarter mile, sluggish, stage 2, zl1
