01-15-2019, 08:56 AM | #1 |
Drives: 2017 CAMARO 2SS Join Date: Jan 2017
Low numbers after tune
Got my car tuned yesterday by local tuner. Car has TSP headers, dry Rotofab and e85(reading 48%at time of dyno run) just trying to see if this is normal. I know numbers don’t matter but I looked at the dyno and it dips around 5.5 to 6.5 rpm.
Thanks for any input |
01-15-2019, 09:05 AM | #2 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
1) What was stock?
2) What do other LT1's do on that exact dyno?
01-15-2019, 09:54 AM | #3 |
BAMF SS
Part it out
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
01-15-2019, 09:57 AM | #4 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
lol i think your numbers are okay, but before you go crazy about it, try a different dyno, some read less then others even with it being a dynojet.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
01-15-2019, 10:07 AM | #5 |
01-15-2019, 10:08 AM | #6 |
01-15-2019, 12:20 PM | #7 |
BAMF SS
01-17-2019, 11:42 AM | #8 |
Drives: 2017 SS 1LE Join Date: Sep 2011
I can almost guarantee the car is pulling timing up top which is the reason for the dip. This is pretty common with headers and even some stock cars, and is also a super easy fix. Do you happen to have a data log?
What tuning solution are you on? Sent from my iPhone using Tapatalk
2017 1SS 1LE - Eibach Springs | Pray IM | Katech TB | Borla 60606 | Corsa Extreme | E85 Flex Tune
01-19-2019, 06:35 AM | #9 |
Drives: 2017 2SS Fifty Join Date: Nov 2016
Almost exactly what I make with same mods. A8
01-19-2019, 07:07 AM | #10 |
Drives: 17 ZL1 Join Date: Mar 2017
Its the tune, most likely hit a torque limit and pulled timing. Who tuned your car?
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
01-21-2019, 10:08 AM | #11 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
You're in North Carolina? Hit up Pray.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
01-21-2019, 11:37 AM | #12 |
Drives: 2016 Camaro SS Join Date: Sep 2018
The numbers are fine, basically the same numbers my cars makes with same mods. On a different dyno it might be + or - 30 hp either way. As for the dip that could be something to look into but don't worry about your numbers.
01-21-2019, 11:50 AM | #13 |
Drives: 2018 SS 1LE Join Date: May 2018
#1 without a baseline you can’t verify what you picked up
Dyno’s, depending on set up, will give very different #’s Hope you used a reputable tuner and not the Craigslist guy who was $200 cheaper than a true shop.
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
01-21-2019, 12:21 PM | #14 | |
lol but he does hondas all the time
