Vararam
Old 01-04-2021, 10:26 PM   #1
econ
Drives: 2013 2ss
Car on jackstands, engine running, tranmission in gear
Any reason not to do this? It can be handy at times for testing, troubleshooting, etc.
I am hesitant because I am not sure about letting the rear suspension sag with power going to the wheels.
I have done this with a solid rear axle and jackstands below the axle housing (suspension loaded). Worked great. Not so sure about the camaro with IRS and the suspension unloaded.
So, what do you think?
econ is offline   Reply With Quote
Old 01-05-2021, 01:32 AM   #2
Camaro__ss
Drives: 2013 L99
I did it trying to isolate the source of a rear end howling noise. I don’t think you can hurt anything, unless you get your face between the tire and the fender.
Camaro__ss is offline   Reply With Quote
Old 01-05-2021, 06:11 AM   #3
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
It'll throw a bunch of warning lights but they'll go away as soon as you drive down the street.
Sent from my Pixel XL using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
larry_g is offline   Reply With Quote
Old 01-05-2021, 07:24 AM   #4
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
not sure the CVs like those angles so be careful. Taking the rear tires off will help.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is online now   Reply With Quote
Old 01-05-2021, 07:56 AM   #5
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Aside from the obvious dangers of a car on jack stands in gear, as long as the RPM is fairly low, CV’s can handle a lot of angle. Angle AND RPM builds heat. The more of both, the more potential for damage - but it would take a while. They use the same ‘Rzeppa’ style CV’s as the main driveshaft in many vehicles. Albeit, lower angle, buy higher RPM.
Proceed with caution! (IMO)
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
Old 01-05-2021, 08:20 AM   #6
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Not Harbor Freight Jack stands I hope
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 01-05-2021, 09:00 AM   #7
BLU DUCE
BLU DUCE's Avatar
Drives: 2011 1SS/RS IBM Camaro
Oh come on. Where is your sence of adventure?
BLU DUCE is offline   Reply With Quote
Old 01-05-2021, 09:08 AM   #8
sdynak
Drives: 2010 1SS
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 01-05-2021, 10:09 AM   #9
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
And the Darwin Award goes to...
SIM GhostrdrZ is offline   Reply With Quote
Old 01-05-2021, 10:14 AM   #10
TheFlyingBananaSS
Old 01-05-2021, 01:17 PM   #11
xstuntman
Drives: 2012 Victory Red LFX
I'm counting the ways it will go wrong but you could monetize it on YouTube to offset your insurance deductible.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
xstuntman is offline   Reply With Quote
Old 01-05-2021, 03:54 PM   #12
gtstorey
Drives: 2010 Camaro SS2,L99, LSA SC
I've done it many times with front wheel drive vehicles. With good jack stands the danger is minimal. Just build up rpm slowly, and be ready to hit the brakes if you get any bad vibration. As an added safety factor you could do it outside and not pointed at anything.
gtstorey is online now   Reply With Quote
Old 01-05-2021, 03:57 PM   #13
vinman
The BBOMG fill-in husband
vinman's Avatar
Drives: 2015 2SS/RS 1LE AKA V1LE
Ever watch Ferris Buellers Day Off???
UPSTATE C5 MEMBER
vinman is offline   Reply With Quote
Old 01-05-2021, 04:23 PM   #14
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Exactly what I was thinking.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
