01-19-2020, 07:57 AM | #29 | |
Now one year later the slow start problem is back. Do you guys think a higher cranking power battery is the answer to the slow cranking?
01-19-2020, 08:04 AM | #30 |
its not the battery. check for loose battery cables at battery and fuse box. check all grounds too.
01-19-2020, 09:26 AM | #31 | |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
01-19-2020, 09:30 AM | #32 | |
Sorry OP for the thread jack. I jumped in because I'm frustrated with the slow starts and the potential of the OEM battery being in the issue. My replacement OEM battery cranked well for a year but now not so much.
01-19-2020, 09:58 AM | #33 |
it was comon and i think there was a TSB on the 16s wit hard start issue. if they replaced the battery for it might be a documented issue. it could still be under warranty.
01-19-2020, 10:37 AM | #34 | |
Drives: '16 Red hot M6 Join Date: Apr 2014
Follow me on Instagram
@julian_delgad0 |
01-19-2020, 10:47 AM | #35 |
Drives: 2SS, CT-R, LC500 Join Date: Jan 2018
The battery gauge, while driving, is supposed to vary between ~12.5 and 14-15.......Just the fact that it drops to 12, does not mean there's something wrong.
If I do a bunch of short drives over a few days (less than 10-15 min), my voltage gauge starts to hover at 14-15. To me, this indicates the battery Charge has been depleted by the repeated starts and short drives. Then I'll do a nice long drive and it will start at 14-15 and then drop down to about ~12.5 eventually. I think this indicates the battery is almost fully charged. |
03-18-2022, 06:14 PM | #36 |
Drives: 2016 2SS 6MT Join Date: Apr 2020
I need to replace mine in my 2016 SS. Car died 5 times in stop and go at low rpm. gauges started dying at heavy throttle. I'm getting zero juice when the alternator isn't spinning.
Is this the correct one? https://www.impactbattery.com/norths...m48-l3-h6.html |
03-18-2022, 06:22 PM | #37 | |
Drives: 2016 1LT 'Vert Join Date: Feb 2022
03-19-2022, 05:24 AM | #38 | |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
03-19-2022, 08:25 AM | #39 | |
'20 ZL1 1LE A10,
03-23-2022, 12:43 PM | #40 |
Drives: 17' Chevy Kamaro SS 6 speed Join Date: Mar 2022
I'm over 53k miles on my 17 SS. Its my daily driver. That puts it at 5 years old and still going strong. How long do these batteries last? Do they give you plenty warning before failing?
03-23-2022, 12:58 PM | #41 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
I just replaced the OEM battery in my '16. Not because it showed signs of dying either, simply because I thought 6-7 years was a good run. Who knows how long it would have really lasted. I just got another AC Delco Battery. Why not, the last one did me just fine.
03-23-2022, 01:03 PM | #42 | |
As to "expected" battery life: 3-7 years. Not at all predictable where you will end up in that range. |
Thread Tools | |
