07-14-2015, 09:37 AM | #1 |
Lsx 427
Have a couple of questions, Have a friend wanting to sale a LSX 427 short block with Lunati Crank, rods, and pistons..for 5 grand, short block has 5,000 miles on it assembly has 0 miles. Stock heads and pan should bolt right up right? Also throwing in Arp bolts and T18 melling hv oil pump. Questions are good deal? What else would i need besides better heads and a tune?
07-14-2015, 09:39 AM | #2 |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
Good deal buy it
07-14-2015, 10:54 AM | #3 |
Drives: 2006 Z06 Join Date: Oct 2010
Assuming all is good, that is a good deal.
Different cam, and I wouldn't put stock ls3 heads on a 4.125 bore setup. It can work, but I would get some aftermarket heads ASAP, and a cam spec'd for a 427. Pan bolts right on. Oil pump should go right on assuming it has the correct short crank. Make sure the crank is correct for your application. Same reluctor and snout length or that is a real pain to fix.
Nick
Corvette Z06 -1200ish rwhp |
07-14-2015, 07:22 PM | #4 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
Even stock LS7 heads would be better, no?
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
07-14-2015, 07:28 PM | #5 |
For power, yes, for reliability, no.
Nick
07-14-2015, 08:20 PM | #6 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
The price is nice if you want to go heavy with a LSX iron block the question is why 5000 miles on the block and not with those parts.... ? just the bare block is like 2200 and can be made into a 500 cube stroker, so maybe someone went Dart block instead and pulled the internals? I bought a 428 stroker from Jerry at SAG performance he is on Ebay selling strokers you should maybe talk to him. I went new g.m. aluminum block as I am a daily driver and the internals I can always use later for a new block if I ever wear the new one out. Our blocks as you know are 1200$ throw away as they can only be honed .020 over and that's if the cast in sleeves are straight.... I thought about going cast iron and could have done it cheaper actually, yet quality is in various upper price range iron blocks, and they can be sleeved later and bored etc for a longer life yet weigh more but are after all stronger.
Just as with my old hot rods though marrying iron and aluminum means re-torque of the head bolts periodically as things expand differently and aluminum intakes would pit eventually also married up to iron mainly probably from the radiator fluid acidity. On my ls3 stroker I had to get a mast Windage tray, and do not know about the LSX for compatability to ls3 parts, you should talk to a machine shop that knows. Just look UP LSX stroker 427 on ebay and you will find custom engine supply Jerry in Angola Indiana, he was a nice guy just a busy machinist.
07-16-2015, 10:25 AM | #7 |
Well now he said he would take 3grand for it plus my short block, (has 36,000 miles on it) so debating I would still need heads, timing chain, cam and a tune that's all I can think? I'm still on the fence about it would be first time short block swap.
