12-09-2020, 03:10 PM | #1 |
Drives: 2020 Camaro SS 1LE Join Date: Nov 2020
Track Preparation
Does anyone have a good guideline for before and after a track day. Just trying to make sure I check all the boxes before my first session. Picked up a 2020 SS 1LE in Oct and plan on hitting the track soon!
12-09-2020, 03:14 PM | #2 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
12-09-2020, 03:44 PM | #3 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Yep, there is the Track Prep Manual, which should have everything you need to know.
In general, it's just about adjusting your tire pressure and make sure everything works, which you would have to go through on a track tech inspection anyway. One thing I personally would add is getting some better brake fluid. When I took mine to the lapping day, I could feel my brakes becoming squishy after a 20-min session and I wasn't even driving hard(I showed the PDR footage to people and they say that I am way too nice with the brakes). So I would pick up something nicer, like the Motul RBF 600 or RBF 660 if you are more serious. I am on Motul DOT 5.1 because I don't track the car that hard. I am more there for the fun but even then, I don't think the stock fluid will cut it.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
12-09-2020, 04:28 PM | #4 |
alignment better brake fluid torque lugnuts fresh oil tow hook send it!!
12-09-2020, 04:32 PM | #5 |
Drives: 2019 Camaro 1SS Join Date: Apr 2019
12-09-2020, 04:43 PM | #6 |
if you have a 1ss you gotta put on the track shield for the brakes also but 1le dont need those
12-09-2020, 05:49 PM | #7 | |
I can help a fellow Texan get started on this adventure. PM me |
12-11-2020, 11:16 PM | #8 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Make sure the car is beyond its break in period (ref manual), as the ELSD really needs it (incl fresh fluid). Beyond it: proper fresh Dexos2 oil per the manual, DOT 4 brake fluid (Castrol SRF is the best, but Willwood EXP is also excellent), adjust tire pressures before, during and after (per the manual) and do a track alignment if you're serious. Have fun! |
12-14-2020, 11:56 AM | #9 |
Thanks for all the advice. Yeah I read the manual and it said pretty much the same things. Oil, tire pressure, fluids, etc. I’m excited. About to schedule a session at Harris Hill Raceway and looking at COTA in March with Edge Addicts!
12-25-2020, 12:30 PM | #10 | |
IYAOYAS
Drives: 22 1LE 2SS M6 Riverside Blue Join Date: Mar 2018
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold 2018 black Camaro 2SS M6 Redline Edition/Traded 2016 summit white Camaro RS V6 M6/Traded |
12-25-2020, 12:56 PM | #11 | |
As its been mentioned just follow the track rep guide (link above). Some novice drivers don't bother with the track alignment but if you plan on being a regular, we max out the camber some more than others.
12-25-2020, 12:59 PM | #12 |
I should be there. Definitely recommend time on smaller tracks before you get on COTA
12-25-2020, 02:05 PM | #13 |
After track day, start thinking about a new set(s) of tires
'20 ZL1 1LE A10,
12-25-2020, 02:13 PM | #14 |
Great advice, but to put it into perspective, they should last 6-7 days (or even a bit longer for a novice level). But, it is always good to have a set on hand.
Also, completely support a prior comment about not starting out on a track like COTA. Best to find a smaller, slower and safer track potential consequences wise, to get a feel of the car, learn the basics well, etc. Enjoy! |
