09-22-2020, 07:31 PM | #1 |
Drives: 2019 Camaro SS Convertible Join Date: Apr 2019
Is an oil leak a common problem?
I have a 2019 Camaro SS with just under 10,000 km on it. Very recently I've noticed a small puddle of what appears to be oil under the engine after the car sits for a few days. I'm not 100% sure it's oil, but it is dark in colour like oil, although it appears to be much thinner than I would expect oil to be. I had a look under the hood and didn't notice anything obvious and haven't had a chance to look underneath yet.
I'll probably have the dealership look into it since it's still under warranty, but are oil leaks a known or common problem with Camaros? Is there something else this might be (given how thin the fluid is that I think is oil)? Thanks.
2019 Camaro 2SS Convertible
Shadow Grey Metallic with Adrenaline Red Interior 6MT, MRC, NPP, Carbon Flash wheels w/ SS wheel caps |
09-22-2020, 07:36 PM | #2 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
check your filter, I had one on my truck not tight and was leaking.
09-22-2020, 07:58 PM | #3 | |
Drives: 2000 Trans Am M6 Join Date: Mar 2018
Loose oil pan bolts have been the source of oil leaks for more than a few forum members. I found my oil pan covered in oil too when I got under the car recently for an oil change. Not what I expected to see on a $40k+ car with 22.5k miles on it. I do not know where the oil is leaking from in my case, but I will take it to the dealer for warranty repair before the next oil change.
2018 - 1SS - 1LE - Red Hot
09-22-2020, 08:37 PM | #4 |
Drives: 2023 SS 1LE Join Date: Mar 2020
Are you sure it’s not water from the A/C condenser?
09-22-2020, 10:13 PM | #5 |
Drives: Hyper Blue 2SS Join Date: Jun 2013
check if the oil the filter is tight enough
located under the engine driver side .
2SS, Hyper Blue, 8-Speed Automatic, NPP Exhaust, Magnetic Ride Control, Sunroof, Navigation, 5-Spoke Low-Gloss Black Wheels, Black Bowtie Emblems, Cargo Mat/Net
Mods: XPEL - Hood, Bumper, Headlights, & Side Mirrors JWM - Side Markers ZL1 Addons - Deluxe Rock Guards & Red Lift Pads GM - Dark Tail Lamps MRR - Gloss Black M017s |
09-22-2020, 11:06 PM | #6 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Well, it is a
Cracked Heads, Every Valve Rattles, Oil Leaks Every Time, so... All joking aside, if it's oil, I would check the oil filter. Maybe it's not tight enough, maybe someone forgot to remove the old gasket that got stuck to the car and put the new filter on(assuming you had an oil change already), though usually that will cause more than just a minor leak from what I have heard. I was gonna say that as well, could just be plain old water from the A/C, especially since OP said it's thin.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) Last edited by UnknownJinX; 09-23-2020 at 12:20 PM. |
09-23-2020, 08:18 AM | #7 |
Drives: Camaro ZL1 , Corvette ZO6 Join Date: Mar 2019
Maybe put a clean pan under your car and capture a sample of the suspect fluid . You will know for sure if it is oil , condensate or another type of fluid . You could also take the sample with you to the dealer to help them find the leak . Good luck .
09-23-2020, 08:21 AM | #8 | |
Drives: '21 V6 1LE Join Date: Jul 2020
09-23-2020, 08:54 AM | #9 |
I'm pretty sure it's not just water as it has a dark tint to it and feels slicker than just water, although I can't rule out it's not water from the condenser combined with oil. I assume that would not be the case if it's just water from the condenser. The other thing to consider is I almost never drive with the air conditioner on, so unless the condenser runs under scenarios besides using the AC, I don't think I'd even be producing any condensation. Thoughts?
09-23-2020, 08:58 AM | #10 |
Thanks everyone for the suggestions. The last oil change was mid-July and I've only noticed the fluid on the garage floor in the last 2 weeks, so I'm inclined to think that its not related to the oil change (ie/ the filter), although I will have a look. The suggestion that it's AC condenser sounded plausible since the fluid does seem rather thin. I'm going to put a tray under the car tonight as suggested to collect the fluid to get a better sense of what it might be.
09-23-2020, 09:51 PM | #11 |
I drove the truck for 6 months before it turned out enough to start leaking. I really thought I had a rear main seal going out and was actually relieved when I crawled under and found it dripping down the oil filter. Having an aux oil cooler you could have a line leaking too. Trans line are notorious for leaking.
09-24-2020, 05:24 AM | #12 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
I had to have my 2017 Camaro's oil pan resealed under warranty. Was not loose bolts.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
09-24-2020, 08:15 AM | #13 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I get a few drops on the garage floor, 100% it's oil but it's so small and so sporadic that I really don't pay it much attention. Is usually after I've taken it out and ragged on it particularly hard on the back roads. Never seems to be day-in and day-out even though I can run it some what aggressively.
09-24-2020, 10:06 AM | #14 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Where is the LEAK? under the engine, front rear, left right etc.....
I had a leak which turned out to be a pinhole in a WIX filter....it ran back on the engine and I thought it was a transmission cooler leak....
2012 Yukon XL Denali w/ 6.2 AWD |
Thread Tools | |
