Old 08-24-2017, 10:36 AM   #43
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
This car comes stock with 285/305 and I wanted to try something with more tire up front.
seanblurr is offline   Reply With Quote
Old 08-28-2017, 10:14 PM   #44
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
Originally Posted by Lipa View Post
So will they fit on a stock SS without mag ride??
They should clear with no problem since the mag ride struts stick out further than the regular struts from what I'm led to believe but thats just what I've heard and not fact until we can get someone to test it out first.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 08-30-2017, 09:54 AM   #45
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Thanks for the great info Sean!!
From the moment we all heard about the ZL1 1LE, everyone wanted to know if the 1LE wheels would fit the standard ZL1, so I started taking measurements on my ZL1. I didn't know the exact offset of the 1LE wheels for a while, but my guess was really close. I felt like the wheels would "just" fit and would only take minor changes to get them to, if they didn't bolt right up. I appreciate you confirming this. I may look at doing the swap in the future.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 11-01-2017, 01:11 PM   #46
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Originally Posted by glamcem View Post
for the reference, CCW Corsair monoblock forged wheels with 3000 lbs load rating weigh around 20-21 lbs (and below 20 lbs for 18" setup) and they're not much more expensive than the OEMs. (I've seen them go as low as $3000-3400) 6-7 lbs of rotational mass is huge.
Cem, had the same though as I was pricing out a second set of wheels for the ZL1 (Apex's widest is a "11, so no go there). So--I spoke with CCW, unfortunately they can't do any offset below et25, so any fronts for our cars are out. Bummer
Provoste is offline   Reply With Quote
Old 11-05-2017, 12:30 AM   #47
NW Sam
NW Sam's Avatar
Drives: 2017 ZL1 Garnet Red
Have you measured the stock tire height compared to the 1LE set up? I am curious if the speedometer would be accurate. Thanks, Sam.
NW Sam is offline   Reply With Quote
Old 11-05-2017, 01:23 AM   #48
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Hmm interesting.. How aboutt the BC Forged? They're even cheaper than the CCWs and only with 4 weeks wait time (vs 14 weeks with CCWs AFAIK).
Other good option is the new APEX SM 10 wheels in 18" sizes 18x10.5" +22mm and 18x11 +43mm offsets. The fronts will require either 8mm spacer and some grinding or camber plates but it should be doable with some extra grinding and maybe back down the front camber to -2.7 camber from -3.0
glamcem is offline   Reply With Quote
Old 03-08-2018, 05:25 PM   #49
SD1
Drives: 17' GTI DSG SE
Will the SS 1LE wheels fit on the ZL1??
SD1 is offline   Reply With Quote
Old 03-10-2018, 10:48 PM   #50
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | 18 F150
As you know I recently ordered and am awaiting a set of Forgestar CF5V in Super Deep Concave Front and Rear in stock ZL1 offsets and widths...
I'll post once they're on - As my NT01s are in the garage waiting.
I have spacers just in case but I also have the strut tabs ground down a bit... so I likely will not need them ...
-3.0* camber front and -1.25* rear for folks wondering
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!)
'18 F150 Platinum Powerstroke diesel
'22 Kia EV6 First Edition
'18 RS3 (1 of 2) Cumulus Blue
'24 911 T (ordered)
Formers...
'19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 03-11-2018, 02:07 PM   #51
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Yes, they are the same sizes & offsets as the regular ZL1. The ZL1 1LE wheels have been used on a number of SS 1LE's (like mine: -2.8 front / -1.8 rear camber) with no spacers - just the bit of grinding on the front struts.
RUQWIKR is offline   Reply With Quote
Old 03-11-2018, 03:05 PM   #52
RideZX6R
RideZX6R's Avatar
Good to know that I likely won't need any spacers for my new CF5Vs then
1.8 in rear - NICE
-Seven
'24 911 T (ordered)
Formers...
Old 04-27-2018, 11:07 AM   #53
rfm4000
Drives: 2017 SS 1LE SIM
Has anyone been consistently running the zl1 1le knock offs with these tires, on an ss 1le, with any problems. Id imagine we would be using a small spacer.
rfm4000 is offline   Reply With Quote
Old 04-27-2018, 11:22 AM   #54
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
I can't answer that question, but I can add that I recently mounted up 5th Gen Z28 wheels to my SS 1LE.
No spacer, but a grind of the strut, and took a little camber out of the knuckle which was corrected at the top with camber plates. I have -3 degrees of camber with no spacer as a result, so they're tucked in as close as possible.
Chris V is offline   Reply With Quote
Old 04-27-2018, 12:05 PM   #55
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
Well if by knock offs you mean the M716 you will not need a spacer at all. is a direct Camaro fit.
thanks to Sean we created the 19x10.5 14et along with a 19x11 rear
or just the standard 19x10 front.
either way they will bolt right on to your car.
Carlos_MRRWheelsInc is offline   Reply With Quote
Old 04-27-2018, 12:32 PM   #56
RideZX6R
RideZX6R's Avatar
Considering no replicas are offered in 19x11 front fitment currently... This question isn't really valid.
-Seven
'24 911 T (ordered)
Formers...
