Old 06-22-2020, 01:23 PM   #1
H4r0ld
H4r0ld's Avatar
Drives: 2019 2SS
Lightbulb Anyone disable noise cancellation on a Bose system?
Being a Camaro and all, I'd like to hear more of the engine when I drive.
Have any of you guys successfully disabled noise cancellation on a Bose system?
Did you lose any other functionality?
H4r0ld is offline   Reply With Quote
Old 06-22-2020, 05:41 PM   #2
Xaxas
Xaxas's Avatar
Drives: 2019 2SS 1LE
Sub-thump sells a harness for $23
Current: 2019 2SS 1LE aka "Blanc"
Previous: 2017 2LT aka "Noire"
Mods: Chevrolet Performance Suspension || K&N Cold Air Intake || Borla ATAK Mufflers + Catback system || MRR 650 ZL1 replicas with squared 285/30 Michelin Pilot Sport 4S || ZZP 4 piston brake kit + braided brake lines || BMR everything (Solid/Lockout cradle bushing are a MUST in Camaros)
Xaxas is offline   Reply With Quote
Old 06-22-2020, 08:32 PM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Yep, that’s the way to go.
Joshinator99 is online now   Reply With Quote
Old 06-24-2020, 10:00 AM   #4
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
Just unplug one of the microphones in the doors.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 06-24-2020, 11:39 AM   #5
ctrlz
AFAIK, the noise cancellation reduces the sound of drivetrain rumble at low engine rpms. It has no effect on exhaust tone or any intake sounds, etc. you get when accelerating.
So, unless you are a big fan of rumble when cruising at 1300 rpm, I would not bother trying to disable this.
This is really there so people don't think their cars are about to stall when cruising at low rpms. The engine can handle it, and you get better fuel economy. The problem is we think that noise means the engine is struggling.
Old 06-27-2020, 01:21 PM   #6
SliChillax
SliChillax's Avatar
Drives: Camaro ZL1 A10, F-Type R, RR Sport
I bought that harness that disables it, couldn't tell any difference.
SliChillax is offline   Reply With Quote
Old 06-30-2020, 12:35 AM   #7
Zr8000
Drives: Chevy Camaro
Same here. I can’t tell any difference
Zr8000 is offline   Reply With Quote
