Old 01-16-2018, 07:00 PM   #1
dmeadows013
Drives: 2017 50th Anniversary V6
Rear Diffuser Replacement
I just bought the quad tipped rear diffuser and it’s currently getting painted, so I’m just waiting on that to install my new exhaust system. Is it possible/feasible to replace the rear diffuser without removing the wheels and the whole bumper? If not, how much would it generally cost for a shop to do it for me, and could I use the quad tipped diffuser with my single tips until I get a chance to get my new system installed?
dmeadows013 is offline   Reply With Quote
Old 01-16-2018, 09:12 PM   #2
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Welcome! Whether you have a shop do the install or you do it, the rear bumper will need to be removed. You also can run your dual tip exhaust with the quad diffuser, although it might look a bit odd, until you get your quad exhaust. You can do a search on removing the rear fascia if you decide to tackle this project, most shops will charge you an hourly rate, a reputable one will have a schematic of the rear bumper removal and should be able to give you a fairly accurate quote. Good Luck!
1hprush is offline   Reply With Quote
Old 01-16-2018, 10:21 PM   #3
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
You can do it both ways. Here are the links on how to remove it.
https://youtu.be/h22plWwhsNA
https://youtu.be/7vb6s9lDcb0
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 01-22-2018, 05:40 AM   #4
Jessyb13
Jessyb13's Avatar
Drives: 2017 Camaro 1SS
I have a lift, I did it without removing the rear tires or bumper, so if you have access to one you’re good. If not you it’ll just be annoying on the ground
2017 Hyper Blue 1SS (M6) / (20x10.5)(20x9.5) Feradda FR2 Wheels / Mishimoto CAI / Kooks 1 7/8” Catless Longtube Headers / Custom 3” Mid-Pipe w/ Flowmaster Super 10 Mufflers / Mishimoto Catch Can
Jessyb13 is offline   Reply With Quote
