TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 01-20-2012, 07:30 AM   #43
Bolt-onC6
Drives: 2017 Corvette
Originally Posted by BigHemiSrt View Post
If this car can get a 1.5 short time @ 119 expect times to be around 11.2-11.5.
Without tuning there is most likely no way it will get a 1.5 60' time. GM will have engineered too much torque management to launch that good.
Bolt-onC6 is offline   Reply With Quote
Old 01-20-2012, 11:52 AM   #44
Lee9710
Drives: 2013 Summit White ZL1
Send a message via Yahoo to Lee9710
These times scare me a little but with that trap speed it should be mid 11s. I used to do 11.4s with a 1.7 60 ft at 117 mph before my motor change. Now I run low 10s but that trap speed with that 1/4 doesn't make sense to me. Maybe the tires are crap on the ZL1 just like they were on my SS....
Proud Owner of the baddest Camaro ever built
ZL1
Lee9710 is offline   Reply With Quote
Old 01-20-2012, 12:30 PM   #45
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
The tires on ZL1 are obviously not tailored directly for the strip. You can't have it both ways. There's no sidewall and some of the reported tests were nowhere near optimized for traction or even power.
Passing judgement this early is really premature.
'20 ZL1 Black "Fury"
Old 01-20-2012, 12:48 PM   #46
blackSSRS
Drives: 2010 RS
maybe it'll have optional tires like vettes. there performance tires are supposed to be for traction and power. which is why i'm wondering about radz28's comment where tires basically aren't performance not being designed for power or traction, yet vettes come with them as upgrades
blackSSRS is offline   Reply With Quote
Old 01-20-2012, 01:41 PM   #47
Lee9710
However it is easy to pass judgement when the times are slower than expected with that much power. Has to be crap tires.....no other explanation. Especially when a CTS V runs pretty much the same times with more weight and less power.
ZL1
Old 01-20-2012, 02:19 PM   #48
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Sucks for times but with those temps the car will be making more hp. There fore the times will suck but the MPH will be better than what will be normal/average. This is if it was at or near sea level.
Atleast mid 11's. With a 1.5 sixty foot my car runs mid 11's @ 117. If this car can get a 1.5 short time @ 119 expect times to be around 11.2-11.5.
The ZL1 is going to need drag radials to pull that off.
The ZL1 heavy car like the ZL1 with stock rubber pulling those kind of
60' times.
Most owners would will probably be happy just to pull sub 2.0 sec 60' times on the stock rubber with all the power.
But I do understand what your saying. Check my sig, I'm running 12.1 with only 113 mph traps. But I'm running drag radials and pulling 1.77 sec 60' times.
SGOS252382 is offline   Reply With Quote
Old 01-20-2012, 02:53 PM   #49
b4z
Drives: '06 Pontiac GTO M6, '19 F150 2.7TT
would like to see the CTS-V vs. the ZL1.
would be interesting to see how much quicker the ZL1 is.
b4z is offline   Reply With Quote
Old 01-20-2012, 04:05 PM   #50
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I likey!!! Still that's not the matchup of the decade...
Old 01-20-2012, 08:51 PM   #51
10redrocket
Drives: 2SS Camaro LS3
I didn't see which tires the Mustang was running so I'm not sure if the comparison was fair.
However the ZL1 comes with Ultra-High Performance tires (Eagle F1 Supercar G2's) meant for summer. The hotter the environment the better the traction will be. I can't remember where I read this but here it is, these tires are not supposed to be used in temps below 50 degrees and should never be stored at temps less than 20 degrees. Not sure why but I'm guessing that at such a low temp the structure/chem makeup of the tire is altered.
For you SS guys with the Perrelis. Have you noticed that the cooler the pavement the worse your traction is?
Also, this type of tire absolutely sucks at the strip, even on a hot day.
Let the temperature debate begin, LOL!
RECEIVED 5/22/09 - 2SS, SIM with CGM stripes, Black Leather, Polished 20's, Sunroof, LS3.
Past Rides: 69 Camaro RS Small Block
67 Chevelle SS Big Block
05 Cobalt SS Supercharged
07 Cobalt SS Supercharged
10 Camaro 2SS LS3
Soon: 18 Camaro 2SS 1LE
10redrocket is offline   Reply With Quote
Old 01-21-2012, 10:21 AM   #52
b4z
You guys need to get the January 23, 2012. Autoweek. One of the comments in there
Was that randy Pobst who drove both the zl1 and Laguna seca for motor trend was not as fast in the zl1 as Aaron Link, GMs engineer/test driver.Aaron link was the guy who drove the nurburgring lap.
Old 01-21-2012, 11:37 PM   #53
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
What is...fair?
I'd consider factory-spec "fair" when considering these sorts of reviews. No need to search for details and try to invalidate the comparison.
I've always held that these articles were for entertainment value-only. This is no different. It just so happens the ZL1 came out on top in many of them. Good to see for a change.
Thanks for posting these, guys -- and thanks for adding them to the homepage Tran, was able to catch them at work! Made my day!!
Old 01-22-2012, 04:01 PM   #54
BigHemiSrt
Drives: 07 Dodge Charger SRT8
Hmm...that sucks. I was thinkin with the roots and all that instant TQ it woulda been able to pull it off with some drag radials or slicks.
BigHemiSrt is offline   Reply With Quote
Old 01-22-2012, 06:20 PM   #55
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
Magazine Recap of key facts relating to speed.
Car and Driver Mag
Curb weight: 4120 lb
C/D TEST RESULTS:
Zero to 60 mph: 4.1 sec
Zero to 100 mph: 8.9 sec
Zero to 130 mph: 14.7 sec
Street start, 5–60 mph: 4.6 sec
Top gear, 30–50 mph: 7.8 sec
Top gear, 50–70 mph: 6.7 sec
Standing ¼-mile: 12.3 sec @ 119 mph
Top speed (drag ltd, mfr's claim): 180 mph
Braking, 70–0 mph: 165 ft
Roadholding, 250-ft-dia skidpad: 0.98 g
Motor Trend Mag
ZL1 Boss 302
Curb Weight 4051 lb 3638 lb
TEST DATA
ACCELERATION TO MPH
ZL1 / Boss
0-30 1.6 / 1.7 sec
0-40 2.2 / 2.3
0-50 2.9 / 3.1
0-60 3.8 / 4.0
0-70 4.8 / 5.1
0-80 6.0 / 6.4
0-90 7.3 / 7.9
0-100 8.7 / 9.5
PASSING, 45-65 MPH 1.7 1.7
ZL1 / Boss
QUARTER MILE 12.1 sec @ 117.4 mph / 12.4 sec @ 113.9 mph
BRAKING, 60-0 MPH 108 ft 112 ft
LATERAL ACCELERATION 1.00 g (avg) 1.01 g (avg)
2.2-MI ROAD COURSE LAP 01:41.3 01:43.7
TOP-GEAR REVS @ 60 MPH 1700 rpm 1950 rpm
Autoweek Mag
CURB WT: 4120 lb.
0-60 MPH 3.9 sec (auto), 4.0 sec (manual)
1/4 Mile 12.0 (auto), 12.1 (manual)
AUTOMOBILE Mag
Weight 4084 lb..
0-60 4.3
0-100 9.5
1/4 mi. 12.6 @ 116 mph
htron50 is offline   Reply With Quote
Old 01-22-2012, 08:12 PM   #56
ZL1NC
ZL1NC's Avatar
Drives: 2013 Inferno Orange ZL1 #288
Interesting statement in Popular Mechanics:
Favorite Detail: In muscle cars, the automatic transmission is usually an afterthought. But the ZL1's six-speed auto slushbox is joyously effective. The manual mode—engaged via steering-wheel-mounted paddles—is responsive, and the automatic car is easier to launch. GM engineers claim that the automatic transmission makes for quicker quarter-mile runs, but in our testing, the manual was the better sprinter. The difference, however, was miniscule—the auto Camaro passed the quarter-mile in 12.58 seconds, while the manual car did it in 12.57.
Not that it really matters because I think we all will enjoy our cars no matter what transmission they are equipped with but some of our members have been caught up and gloating at the GM statement..
Read more: 2012 Chevrolet Camaro ZL1 Test Drive - Popular Mechanics
David
ZL1NC is offline   Reply With Quote
2012 camaro z1l review, 2012 camaro zl1, 2012 camaro zl1 reviews, 2012 zl1, 2013 camaro zl1, 2013 camaro zl1 review, 2013 camaro zl1 reviews, 2013 zl1, camaro zl1, camaro zl1 forum, camaro zl1 forums, camaro zl1 info, camaro zl1 review, camaro zl1 reviews, chevrolet camaro zl1, chevy camaro zl1, chevy camaro zl1 forum, chevy camaro zl1 info, zl1 camaro, zl1 forum, zl1 forums, zl1 info, zl1 review, zl1 reviews
Shno's House of Z Number 3 Camaro Z/28 Forum - Z/28 Specific Topics 17976 12-27-2021 12:07 PM
SEMA Show 2011 - New Camaro Products Showcase! Sean@Phastek Camaro Photos | Spyshots | Video | Media Gallery 85 01-16-2012 10:51 PM
Gran Turismo 5... No Camaro? 5thGenOwner 5th Gen Camaro SS LS LT General Discussions 111 12-06-2011 10:06 AM
Think about this and the Z28 5th gen 13F20 Camaro ZL1 Forum - ZL1 Specific Topics 41 09-04-2010 12:59 AM
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 338 04-15-2009 05:33 PM
