04-17-2022, 11:44 AM | #253 | |
'20 ZL1 1LE A10,
05-17-2022, 03:17 PM | #254 |
Drives: 17 Chevy Camaro ZL1 Join Date: Apr 2022
Not sure if you have found anything out. I am also looking at adding these to my ZL1. I see it's been a few months since you asked. Have you done any of these to yours? Also, I am going to assume that these parts were made for us SS/RS/ZL1 owners
05-18-2022, 07:52 AM | #255 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
@L8ERBRO
You can paint the ZLE canards and all that jazz up front. I had my bezels smoothed and painted mosaic black, the canards were painted gloss black to match the car (left texture). My painter accidently painted the canards mosaic black. I almost left them as such since I wasn't 100% sure I wanted black, but when I held them up to the car and just didn't like it so they went gloss black.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
04-08-2023, 11:08 AM | #256 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
Did anyone skip buying the 1LE wiring harness? I just electric taped the DRL connector and zip tied it to the bumper. I figured this would be an open circuit and wouldn’t cause an issue. But I just had a “Battery Saver Active” pop up on the dash and wondering if it’s draining the battery somehow.
EDIT: Infotainment display was staying on the whole time trying to update, draining the battery. 1LE aero conversion was just a coincidence. Last edited by Slurpee; 04-16-2023 at 07:44 AM. |
02-19-2024, 03:32 PM | #257 |
TikTok: VenomZL1
Drives: 2023 Camaro ZL1 Join Date: Jan 2024
Just finished putting the 1LE grilles and front splitter on my ZL1. For anybody that's done this before or has a 1LE. Are these two little tabs on the lower grille basically almost supposed touch or touch the bumper energy absorber cover behind the grille? Just want to make sure I have it all seated correctly.
02-19-2024, 04:21 PM | #258 |
Drives: 2018 NFG ZL1-1LE Join Date: Jun 2018
Yes, that looks correct. That is how it is on my ZLE.
02-19-2024, 05:13 PM | #259 |
TikTok: VenomZL1
