Vararam
Old 04-01-2021, 06:57 PM   #1
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
What compression ratio for agp twins
Having a 427 dart eliminator block built by tms and wanna to know what the agp twin kit guys are running for comp ratio. End whp goal is 1200, 93 octane only with possibility of meth and will mostly be a streetcar.
_Onyx_Wolf_ is offline   Reply With Quote
Old 04-01-2021, 08:01 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
11:1
wanted the car to not be a dog on the street for daily but still be able to lay the boost into it at the races
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 04-01-2021, 09:41 PM   #3
eLeSthree
Drives: 2011 Camaro SS 6sp
93 only, i’d probably go lower. Im at 10.3 and its got plenty of grunt off boost. I woul just talk to Dustin or one of the guys there and get their recommendation.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 04-02-2021, 12:27 PM   #4
_Onyx_Wolf_
Kevin at tms recommended 9 something compression ratio, just wanted to see what others were running. Any recommendations on a good sealing head gasket? 4.125 bore with arp regular sized studs 6 bolt head setup.
Old 04-02-2021, 12:29 PM   #5
dreksnot
dreksnot's Avatar
I've hear opposing arguments about choosing CR with boost. Some say go low CR so you can crank up the boost with more "margin." Others say high CR will give you more power, but you have to be conservative with the timing. Perhaps it all depends on how one wants to use the car. Either way when done correctly won't be wrong, IMO.
Old 04-02-2021, 01:39 PM   #6
G8One2
Drives: 2014 Camaro 2SS
Static CR really doesnt mean much. Valve events dictate your effective (Dynamic Compression) in a more meaningful number. If you dont know what it is, its kind of a crap shoot on what CR to run. The higher the better for off boost, but too high will limit how much boosts you can run. I think 8.0:1 DCR is kind of a sweet spot for boosted applications, but thats just my opinion. It really kind of varies depending on build. Every car is different.
G8One2 is offline   Reply With Quote
Old 04-03-2021, 09:19 AM   #7
Rem0v3r
Drives: 2013 ss2 vert l99
Just put it on E. you've got thousands into your build, dont risk it running shitty gas.
Rem0v3r is offline   Reply With Quote
Old 04-03-2021, 12:41 PM   #8
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Im at 11:1 and will be running 10lbs on 93 to start. May switch to E depending
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 04-04-2021, 07:46 AM   #9
_Onyx_Wolf_
None in my area
Old 04-16-2021, 06:07 PM   #10
_Onyx_Wolf_
Going with a 9.5:1 compression ratio and rings gapped for boost.
Old 04-16-2021, 09:08 PM   #11
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
11:1 seems high to me, just saying.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 04-17-2021, 09:18 AM   #12
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Thats not far off factory compression. Compression is free power. It's not 1980 anymore.
Thats just static compression, dynamic is something completely different
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 04-17-2021, 02:03 PM   #13
stevieturbo
Drives: it changes
93 only, I'd definitely be into the 9's
Adding more boost is easy to make power.
When you're knock limited through fuel/too high CR....there is no fix when on pump fuel only.
And a 427 is never going to be a dog off boost.
stevieturbo is offline   Reply With Quote
Old 04-17-2021, 04:24 PM   #14
gunchamp
gunchamp's Avatar
This, its all in the tune. Its not old school anymore. Lots of cars running relatively high compression with boost
