01-26-2021, 04:20 PM | #1 | |
Does Borla S Type/2nd cat delete need a tune?
So if I install a Borla S Type full exhaust and also do a 2nd Cat delete will the car need to be tuned?
So it will sound like this...
2018 ZLE - M6, Nightfall Gray
GM previously owned: 2014 SS M6 2014 ZL1 M6 2019 ZL1 M6 2016 Z06 M6 Last edited by LT4 650; 01-26-2021 at 04:35 PM. |
01-26-2021, 05:44 PM | #2 |
You’ll be fine with those mods. If you mess with the primary cats or obviously headers you’ll need a tune.
2020 ZLE Roto-Fab dry
2018 Camaro 2SS 1LE - 2" TSP catless headers, Pray Ported stock IM/TB, Rotofab dry, DSX FF kit, dyno tuned by Pray. SOLD |
01-27-2021, 09:11 AM | #3 |
Thanks
GM previously owned: 2014 SS M6 2014 ZL1 M6 2019 ZL1 M6 2016 Z06 M6 |
01-27-2021, 10:54 AM | #4 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
So the ECM is fine with the rear O2 sensors deleted or just blowing in the wind? Won't it at least throw a code?
01-27-2021, 08:35 PM | #5 |
I don’t believe so. I ended up going with most of the bolt-on stuff in my SS, but I read that an exhaust & secondary cat delete won’t throw codes.
01-27-2021, 08:40 PM | #6 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
If you buy link pipes from one of the major companies they should have bungs for the rear sensors, so they are still there even though the secondary cats are gone.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
01-28-2021, 06:34 AM | #7 |
ok, thanks. Makes sense. Now that I think about it, the HF cats I put on my 2010 SS had bungs for the rears, but they also came with an extension you had to screw in to keep the rear sensors mostly out of the stream or it would throw a code.
