Vararam
Old 11-26-2015, 09:55 AM   #1
pancherj
Drives: 2010 Camaro SS
Eliminating Oil Cooler
I've seen lots of posts on adding an external engine oil cooler. What about eliminating it all together? I developed the dreaded leak and want to get it fixed ASAP. Any pictures or part numbers from guys that have done this?
pancherj is offline   Reply With Quote
Old 11-26-2015, 10:17 AM   #2
Unreal
Drives: 2006 Z06
GTO oil block off plate from dealer
Or they are all over amazon, or summit has them
GM GTO OFAC Part Number 12577903
http://www.amazon.com/Billet-Cooler-.../dp/B00LV1JAW6
http://www.summitracing.com/parts/su...OW4aArVn8P8HAQ
If you don't road race or do track stuff, a great cheap/easy mod.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 11-26-2015, 12:03 PM   #3
pancherj
That's perfect Unreal thanks!!
Old 11-26-2015, 01:25 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You'll also also need a screw in freeze plug for the block. GM part number 11588949 or whatever part number superceded it.
Old 11-26-2015, 01:35 PM   #5
pancherj
Is there also an issue with the radiator hose? The car isn't here right now, but I thought there was a coolant line that ran down there to the cooler.
Old 11-26-2015, 01:46 PM   #6
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Yes. I believe 2012+ radiator hose is what you need.
DarkCry956 is offline   Reply With Quote
Old 11-26-2015, 01:53 PM   #7
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You'll need to splice in a piece to eliminate the "T" or take your hose to an auto parts store and compare it to ones they have to get a similar shaped one (minus the "T"). If I remember correctly, the one out of an LS1 camaro (98-02) is close enough to work.
Or get GM PN 22962571. It is the factory hose for 2012+ SS camaros and doesn't have the "T". GM changed from splicing into the upper radiator hose in 2012 to running a line from the bottom of the radiator to the oil cooler/heater thing.
Darkcry beat me.
Old 11-26-2015, 02:43 PM   #8
pancherj
Thanks for the help everyone! I appreciate it.
Old 11-27-2015, 10:52 AM   #9
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I'm not FI but I did all the above to delete my oil cooler.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 12-17-2015, 01:01 PM   #10
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
Would there be anything different in doing this for a 2012 LS3 with the radiator hose being different? Thanks in advance!
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 12-17-2015, 03:18 PM   #11
pancherj
Other than the radiator hose (you should already have the correct one), everything else should be the same.
Old 12-20-2015, 06:10 PM   #12
xc_SS/RS
Drives: 2010 Camaro SS/RS
Curious why one would do this?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 12-21-2015, 11:27 AM   #13
pancherj
Lots of leaks with the factory system. LS engines were going out the door by the millions before GM added the cooler. Maybe if they had done a better job on the engineering of the oil cooler system, the problems wouldn't be so pervasive in the Camaro and corvette community.
Old 12-21-2015, 01:03 PM   #14
xc_SS/RS
Yeah I can definitely see why you would change it to a different external cooler because of leaks but why would you delete it all together? It works to an extent, not as good as an external cooler that's in the grill area but removing it seems like a bad idea as the oil will stay warmer and be a higher temperature during normal operation.
2010 2SS/RS
