Go Back   CAMARO6 > CAMARO6.com General Forums > Regional Sections > CANADA
Old 07-03-2020, 09:26 AM   #1
V8RWD
V8RWD's Avatar
Drives: 2017 Camaro SS 50th
Canadian Dealer Service Cost
Hey Guys,
For those that get their cars serviced at the GM Dealership:
1. How much are you paying for oil changes on your Camaro SS?
2. Has anyone done a tranny fluid flush on an A8? Local dealer quoted me first $200 over the phone, then later $600 after looking at it. Apparently the new Camaro SS is "like some of their new pickup trucks", where their standard machine cannot be used, and is labor intensive.
V8RWD is offline   Reply With Quote
Old 07-03-2020, 09:59 PM   #2
DarkCydeCA
DarkCydeCA's Avatar
Drives: 2018 Camaro 2SS
Can't comment on the oil changes, but I know from reading around that the trans flush requires a specific machine that sucks the old fluid out and pumps the new fluid into the transmission. Between that and having a specific Mobil formulated fluid to avoid shudder in the A8 probably makes it fairly expensive.
2018 2SS - Unmodified
DarkCydeCA is offline   Reply With Quote
Old 07-03-2020, 10:02 PM   #3
Originally Posted by V8RWD View Post
Hey Guys,
I'm not in Canada, but that is partly true, the flush requires special equipment. However, the allocated labor time as per the applicable TSB is only 1.1 hours, my trans was done in about 1.5, so $600 is pretty steep even in Canadian dollars. The amount of fluid required is 20 quarts at about $7 a quart retail, the dealership probably sources it cheaper.
Old 07-03-2020, 10:27 PM   #4
Cyrus
Cyrus's Avatar
Drives: 50th 2SS
$600 seems too much. I'd say $200 - $350 CND for a tranny flush. Also maybe depends where in Canada your located.
50th Anniversary, 2SS, Build#5771, A8, MRC, NPP, NAV, Sunroof, GM Performance CAI, Trifecta Tuned, GM splash guards, Black illuminated bowtie, GM smoked tail lights & third brake light, GM Fifty floor mats, Strut tower brace, JWM side markers, 20% window tint, Sto N Sho front license plate bracket
Cyrus is offline   Reply With Quote
Old 07-06-2020, 09:58 AM   #5
Lostx403
Drives: 19 SS
Pretty sure my last oil change cost $83 at the dealership a month or so ago.
Lostx403 is offline   Reply With Quote
Old 07-11-2020, 07:52 PM   #6
Cyrus
Cyrus's Avatar
Drives: 50th 2SS
Oil change on these cars should be more than $83 if your getting full synthetic oil which should be mandatory IMO. I'm guessing closer to $150 CDN for full synthetic. I haven't had to get one yet so I really don't know for sure.
Old 07-11-2020, 09:20 PM   #7
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
Have you bought your car used? Cause after 3 years you are due for an oil change haha.
I have had all my oil change done for free (4 oil changes for free when I bought the car) so I can't tell how much it is. But I have the I4 with only 5quarts of oil so that shouldn't be representative of what it would cost you.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 07-13-2020, 07:03 AM   #8
Dale Zee
Dale Zee's Avatar
Drives: 2018 Camaro 1SS Nightfall Grey
to do it yourself with full synthetic 10 qts of Pennzoil cost me 85, and that was with it half off at canadian tire. so id second the 150.00 range for one done at the dealer.
as for the tranny flush i had the shudder and that required a triple flush which was covered under warranty thankfully but was 1500.00, so id estimate the 300.00 range max for a single regular flush!
Dale Zee is offline   Reply With Quote
Old 07-13-2020, 08:12 AM   #9
Dale Zee, unless the flush was done with the correct fluid (check the part number on the invoice, it should be 19417577 for Mobil 1 Synthetic LV ATF HP), the shudder will return.
You may want to visit the dealer and get them to do a single flush based on technical service bulletin 18-NA-355 ("Shake and/or Shudder During Light Throttle Acceleration", Aug 2019) before your torque converter sustains too much damage, because then you'll have an even more difficult time getting them to replace it for free.
Old 07-13-2020, 08:51 PM   #10
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
Ive had about 30 or so oil changes at about three different dealerships - and they average 85 to 105 plus taxes.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 07-21-2020, 11:48 AM   #11
V8RWD
V8RWD's Avatar
Could you name a couple? Preferably on the west side
Last couple times, it was $160 in Burlington.
Old 07-21-2020, 12:15 PM   #12
Cyrus
Cyrus's Avatar
Drives: 50th 2SS
160 sounds about right if its full synthetic.
