Old 02-02-2019, 10:35 AM   #1
Wheat_Fed_SS
Wheat_Fed_SS's Avatar
Drives: 2016 Camaro SS
Dsx flex fuel kit with msd 2 step
Would this even be possible to do? The Dsx flex fuel kit hooks up to the #8 coil pack but I’m also wanting to do msd 2 step which we all know hooks into the coil packs as well.. just wondering if anyone else has or knows someone that did both and how they did it.. thanks in advance
Wheat_Fed_SS is offline   Reply With Quote
Old 02-02-2019, 12:16 PM   #2
oldman
Drives: SS 6 speed of course
AFAIK, the kit can reach the next coil pack with no issues. In fact, I think that is where mine actually is.
Old 02-02-2019, 05:18 PM   #3
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
You could probably just piggy back it into the connector of the MSD or run a wire to the harness under the fuse block like other kits
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 07-08-2020, 06:37 PM   #4
Bomicino
Drives: 2020 LT1
I know this is old, but what route was taken? Ive got flex, and my 2 step ships on the 17th.
Bomicino is offline   Reply With Quote
Old 07-08-2020, 07:37 PM   #5
parbreak
Drives: 2017 50th Camaro SS
BTW, you don't have to put the DSX on #8. We did #4 and it's just fine.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 07-08-2020, 07:52 PM   #6
s346k
s346k's Avatar
Drives: like an old lady
good question. makes you wonder what the flex fuel sensor does while the car is on the 2 step
Old 07-08-2020, 09:06 PM   #7
NYblack1le
Drives: 2018 1SS 1LE
https://www.gen5diy.com/products/16-...-power-harness
Use this power harness along with the dsx setup. Eliminates piggy backing the coil pack harness.
NYblack1le is offline   Reply With Quote
Old 07-12-2020, 01:52 PM   #8
Bomicino
Drives: 2020 LT1
Perfect! Thanks. I'll be ordering that up, problem solved.
