01-17-2021, 08:11 PM | #1 |
Drives: 2013 Camaro 2SS/RS Join Date: Aug 2017
Need Help / Suggestions
Hello everyone I am asking for help & suggestions on the next step of my build. Current mods are listed in the signature place below.
But I am currently upgrading - TSP Stage 3 Cam w/ VVT Delete Corsa Extreme Cat-Back Exhaust New Powerbond Pulley System (This what I currently have and waiting to be installed) Now, this is where I need help & suggestion for more supporting mods: (What I am thinking so far) Suspension (Full) 3.91 Ratio Ring & Pinion set (maybe Richmond installation Kit, no idea what that is) ZL1 fuel pump with bigger Injectors (or any other is better opinion) Bigger tires Driveshaft (unless stock can hold enough) (I believe I am forgetting things but lets start here) intermediate level of knowlegede, so description and helpful tips and suggestion much appreciated. Trying to learn more.
TSP Stage 2 L99VVT-2.2 Camshaft 227/239, .629/.629, 113 LSA, Circle D Converter 3000-3200 PRC 260cc, Cylinder Head (Ported for the camshaft)
TSP.660" Dual Spring Kit w/ PAC Dual Springs & Titanium Retainers, 2.165"/1.59" Stainless Valves w/ Hollow Stem Intake, Comp Phase Limiter, 7.5" Push Length Rod, New GM VVT Camshaft Bolts, D.O.D Delete Kit, Ported Intake Manifold, Kooks High Flow Catted-Long Tube Headers, Flowmaster Outlaw Cat-back Exhausts Cold Air Inductions Cold Air Intake, 95MM Throttle Body Tuned on 91 Octane Gas |
01-17-2021, 09:25 PM | #2 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
It really depends on what this build goal is. I had the Richmond 3.91's and they are strong, no wine, and tons of fun. Make sure the installer knows how to setup a rear or you can wind up with a wine or worse.
Fual wise a ZL1 pump is good to around 700hp give or take. If you plan on more than do a dual pump now. Anything from 1000 to 1300 injectors can hold you well into 4 figures hp wise. Big power requires good rubber. Drag radials is the way to go. Most run 305's.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
01-17-2021, 11:51 PM | #3 | |
What your opinion on the suspension and driveshaft?
01-18-2021, 08:28 AM | #4 |
At some point you will need suspension upgrades. I did mine as the power grew. I fully expect to break an axle or driveshaft this coming season.
01-18-2021, 08:24 PM | #5 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
ZL1 3.73 diff, axles and BMR suspension.
01-19-2021, 06:14 AM | #6 |
I did get a quote from BMR awhile back for a full suspension kit.
Do you know a good website for pricing?
01-19-2021, 06:14 AM | #7 |
I assumed that just seeing what people opinion and options on it
01-19-2021, 08:42 AM | #8 |
Tri-County Camaro SWFL
Trailing arms, toe links, solid rear subframe bushings, Eaton trutrac, lpw diff cover, dss or gforce axles.
The trailing arms, toe links and bushings will nearly eliminate wheel hop which is the most detrimental thing to the rear. The trutrac will give you a posi rear end and will help with not snapping the ring and pinion gear. Lpw diff cover, idk everyone that does the trutrac has one. Axles, welll thats a no brainer, thats the weakest part in the rear of the car. Stock cars have broken the axles.
01-20-2021, 03:07 PM | #9 |
01-20-2021, 06:47 PM | #10 |
USA-1
No need for ZL1 pump/injectors yet. Driveshaft isn't really worth the money, suspension, yep..I'd repeat what I've done save for having to swap to newer control arms as you already have them.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
01-21-2021, 05:20 PM | #11 |
Drives: 2016 1SS Join Date: Apr 2012
CamaroDreams76 said it well. I would go suspension and drivetrain first. It'll make the car a lot more fun to drive and you will be ready for any power adders afterwords. Trailing arms, toe links, solid rear subframe bushings and axles all first for sure. They will benefit you whether you decide to set your suspension up for drag or street/autocross.
-Sean |
01-21-2021, 05:37 PM | #12 |
Now that's the spirit!
01-21-2021, 07:46 PM | #13 |
USA-1
If it breaks, consider that an opportunity to upgrade! LOL
01-22-2021, 05:57 AM | #14 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Go to a Circle D 4000-4200
